Module AWStats
Revision as of 15:34, 27 March 2013 by Eldy (talk | contribs) (→‎Usage)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2013-03-27
Add, into Dolibarr ERP/CRM software, a new menu entry to screens to read statistics compiled with AWStats log analyzer.
The 4 parameters you can set are available to tell Dolibarr where Dolibarr is installed and how to use it (Installation and setup of AWStats is not part of this module nor this documentation, but is a prerequisite):
  • AWStats data files directory (path on disk):
Put here the path onto your filesystem where you AWStats data files are store (data files are files whose name match awstatsMMYYYY.txt) . If you don't know where is this directory, take a look into /var/lib/awstats or search for files called awstats*0*.txt (with unix command: find / -name awstats*0*.txt).
  • AWStats URL (CGI):
Put here the URL you must type onto your browser to use AWStats from URL. It may be something like http://localhost/cgi-bin/awstats.pl or http://localhost/awstats/. Filling this is not required, be if not provided, link to switch to AWStats URL link will not be visible.
  • Localisation of AWStats program (path on disk):
Put here full path to awstats.pl file. If you don't know where was installed AWStats, take a look if file /usr/lib/cgi-bin/awstats.pl exists. If not, make a search onto disk to awstats.pl file (with unix: find / -name awstats.pl).
  • Limit config shown to this list (empty for no filter or use "," as separator):
Keep this field empty
A menu called AWStats appears when you enable the module. Click onto it, allows you to read all statistics compiled by AWStats.
