Module AWStats FR
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2013-03-27
Intégrer dans le menu, des écrans qui permettent de consulter les statistiques de fréquentation de sites Web/Ftp compilés par AWStats log analyzer.
Les 4 paramètres suivants sont disponibles afin d'indiquer ou a été installé AWStats (l'installation d'AWStats ne fait pas parti de ce module mais est un prérequis):
  • AWStats data files directory (path on disk):
Put here the path onto your filesystem where you AWStats data files are store. If you don't know where is this directory, take a look into /var/lib/awstats or search for files called awstats*.txt
  • AWStats URL (CGI):
Put here the URL you must type onto your browser to use AWStats from URL. It may be something like http://localhost/cgi-bin/awstats.pl. Filling this is not required, be if not provided, link to switch to AWStats URL link will not be visible.
  • Localisation of AWStats program (path on disk):
Put here full path to awstats.pl file. If you don't know where was installed AWStats, take a look if file /usr/lib/cgi-bin/awstats.pl exists. If not, make a search onto disk to awstats.pl file (with unix: find / -name awstats.pl).
  • Limit config shown to this list (empty for no filter or use "," as separator):
Keep this field empty
A compléter
