Module Concat PDF
Revision as of 19:52, 9 March 2013 by Eldy (talk | contribs) (→‎Setup)
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Dolibarr min version: 3.2.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2013-03-9
Allow to merge some PDF documents to the generated PDF files. For examle, to add your conditions and terms into the PDF of an order, or to add a catalog of product into commercial proposals PDFs.
Prerequisites
Dolibarr 3.2.0 or more.
Into the setup page dedicated to module, add file system paths where you store the PDF you want to include into generated documents.
Before clicking on button "Generate" to build a PDF document, select your static PDF file to add. Addition is done at the end of the generated PDF.
