Module Dunning EN
Revision as of 16:19, 27 February 2013 by Gschratzer (talk | contribs)
Dunning
Numero/ID of module 52222
Developer doc. of module Module Dunning (developer)
The dunning module is a tool which allows you to create a list of all open invoices as PDF.
  • - 5 dunning levels are possible
  • send PDF (optional including open invoices) as email
  • To add date for open invoices (don't send rappel to date)
easy see INSTALL Document in module package
To use this module, you must first enable it. For this, with an administrator account, go on page "Home - Setup - Modules". Choose the tab where the module stand. Then click on "Activate".
If an icon appears at end of module line, click on it to access the setup page, specific to this module.
  • 1) Number Model (you must select it)
  • 2) Dunning Level (Number between 1 and 5 possible)
  • 3) Dunning Period in Days (Number between 1 and 30 possible)
  • 4) Calculation of Charge (per invoice or per dunning)
  • 5) add all invoices (pdf) on bottom of dunning pdf
The module should be ready to be use.
Don't forget the user rights!
Examples of use cases
