Dolibarr for Ubuntu or Debian
Revision as of 08:57, 25 January 2013 by Eldy (talk | contribs) (→‎Installation)
Dolibarr for Ubuntu or Debian (DoliDeb) is a version of Dolibarr ERP/CRM, packaged with Mysql, PHP and Apache or Lighttpd, with an automatic installer for Ubuntu or Debian users that don't have any technical knowledge.
In a few seconds, after installing this package, you are able to work on Dolibarr, even if you don't have already a web server or if you don't know what is Apache/Lighttpd, Mysql or PHP. Everything is installed for you.
Dolibarr for Ubuntu and Debian is an "all in one" package that can be downloaded from page http://www.dolibarr.org/downloads/. You will find it into the category "stable versions".
From PPA repository (development or stable version)
  • First define the PPA where Dolibarr packages are hosted
sudo add-apt-repository ppa:eldy/dolibarr-dev
or
sudo add-apt-repository ppa:eldy/dolibarr-stable
If you get the following message after the first line :
sudo: add-apt-repository: command not found
Run this and try again :
sudo apt-get install python-software-properties
  • Then, refresh your database of hosted packages an launch install od Dolibarr package
sudo apt-get update && sudo apt-get install dolibarr
From downloaded .deb package
To install the download .deb package found into the download area of dolibarr.org portal, first install the Dolibarr package.
  • For this, just click on the dolibarr.x.y.z.deb file if you use the file manager nautilus.
If you use a terminal console, type:
$ sudo dpkg -i dolibarr_x.y.z-w.w_all.deb
where x.y.z is the dolibarr version, ex. dolibarr_3.1.0-1.1_all.deb
If an error of dependency occurs, type
$ sudo apt-get install -f
This will fix all your system orphan dependencies.
