Dolibarr for Ubuntu or Debian
Dolibarr for Ubuntu or Debian (DoliDeb) is a version of Dolibarr ERP/CRM, packaged with Mysql, PHP and Apache or Lighttpd, with an automatic installer for Ubuntu or Debian users that don't have any technical knowledge.
In a few seconds, after installing this package, you are able to work on Dolibarr, even if you don't have already a web server or if you don't know what is Apache/Lighttpd, Mysql or PHP. Everything is installed for you.
Dolibarr for Ubuntu and Debian is an "all in one" package that can be downloaded from page http://www.dolibarr.org/downloads/. You will find it into the category "stable versions".
From PPA repository (development version)
sudo add-apt-repository ppa:eldy/dolibarr-dev
sudo apt-get update && sudo apt-get install dolibarr
If you get the following message after the first line :
sudo: add-apt-repository: command not found
Run the following before :
sudo apt-get install python-software-properties
From downloaded .deb package
To install the download .deb package found into the download area of dolibarr.org portal, just click on the dolibarr.x.y.z.deb file if you use the file manager nautilus, or, inside a terminal console, type:
$ sudo dpkg -i dolibarr_x.y.z-w.w_all.deb
where x.y.z is the dolibarr version, ex. dolibarr_3.1.0-1.1_all.deb
If an error of dependency occurs, type
$ sudo apt-get install -f dolibarr_x.y.z-w.w_all.deb
This will fix all your system orphan dependencies.
