Module Google
Module name
Editor / Editeur NLTechno (www.nltechno.com) - www.dolistore.com
Last update date / Date mise à jour fiche / Fecha última actualización 2012-12-29
Add into Dolibarr some Google integration:
  • Add into menu a new entry called "Google Agenda" to show contents of Google agendas.
  • Synchronize any event create/modified into Dolibarr agenda to Google agenda.
  • Add a pictogram near all addresses. A clic show an address inside a map (Google Map).
  • Can add a Google Adsense tag into logon page.
  • Can add a Google Analytics tag into logon page.
From the application
Manually
unzip modulefile.zip
Setup of Agenda features
This module bring two different feature:
Showing Google calendar tab into Agenda view
First feature is to show the Google calendar view into a tab into Agenda view. For this, go onto Google module setup page, tab "View Google calendar" and choose "Activate this tool".
Then for each Google agenda you want to show in menus, you must enter:
  • A label for this Agenda.
  • A color for this Agenda.
  • Google ID of Agenda. It can be found on the Google parameters pages for the agendas like this:
  1. Log to http://calendar.google.com
  2. Click on the "Parameters" link
  3. Click on the name of Agenda to show the Details of agenda.
  4. Search line "URL Address", you will see a text "Agenda ID : theagendaid@gmail.com"
200px
The Agenda ID is value that looks like an email. If you have only one Agenda, it might simply be your Google login.
The other feature is to write/update an event into Google Calendar, each time an event is added/updated into Dolibarr. Synchronization is from Dolibarr to Google. For this, go onto module setup page, tab "Sync to Google Agenda", and enter:
  • Your Google login
  • Your Google password
Setup of Adsense
  • Your adsense customer id (ca-pub-xxxxxx)
Setup of Google analytics
  • Your Google analytics id (something like UA-xxxxxxx-y). You can find this id on Google analytics dashboard.
If you enabled feature to show Google agenda
Choose menu Agenda Google, the agenda will be shown. If you have defined several agendas, you can limit view for only one of them using the left menu. The Google agenda is shown in read only mode. To add event into it, you must click on link "+ Google calendar" at bottom of agenda (this is a Google limit).
For security reasons imposed by Google, the Google calendar view will display correctly only if you are logged in to Google. To facilitate this, it is possible to configure a key to allow the application to offer the Google Logon if you are not connected (See setup of module Google, tab Agenda setup, last section).
Google module add.jpg.
If you activate synchronization
Just go onto Google calendar after creating a Dolibarr event. You should see it into Google.
