Table llx c tva
Revision as of 12:23, 5 September 2012 by Simnandez (talk | contribs) (→‎Table)
Content/Contenu/Contenido
Fr verysmall.png Contient les taux de TVA applicables. Utilisé pour générer des listes déroulantes et trier des résultats.
En verysmall.png Contains the possible VAT rates. Used to generate drop-down lists and filter results.
Es verysmall.png Contiene las tasas de IVA aplicables. Utilizada para generar las listas despleglables y filtar los resultados.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
fk_pays int(11) NO ID of related country (llx_c_pays->rowid)
taux double NO VAT rate
localtax1 double NO 0 Local tax 1 rate (Spain=RE)
localtax2 double NO 0 Local tax 2 rate (Spain=IRPF)
recuperableonly int(11) NO 0 Is the VAT recuperable?
note varchar(128) YES NULL comentary about VAT
active tinyint(4) NO 1 Is the VAT active?
Keys
Key Type Fields
PRIMARY PRIMARY rowid
