Module AWStats
Module name | |
Editor / Editeur | NLTechno (www.nltechno.com) - www.dolistore.com |
Prerequisites / Prérequis |
Dolibarr min version: 3.0.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2012-09-3 |
Note / Nota |
Add, into Dolibarr ERP/CRM software, a new menu entry to screens to read statistics compiled with AWStats log analyzer.
To complete
