Table llx societe
Revision as of 16:53, 9 August 2012 by Eldy (talk | contribs)
Content/Contenu/Contenido
  Contains the list of third parties stored in Dolibarr (thirdparties are customers, suppliers, prospects).
  Contient les tiers enregistrés dans Dolibarr (les tiers sont les clients, fournisseurs ou prospects).
  Contiene los terceros registrados en Dolibarr.
Structure
Table
rowid int(11) NO PRI auto_increment technical index
nom varchar(60) YES NULL name
entity int(11) NO UNI 1 multi company id
ref_ext varchar(60) NO UNI 1 A field only stored and read by dolibarr but not used. You can use it to store your id of tirdparty into another external system. This will help synchro tools.
statut tinyint(4) YES 0 state
parent int(11) YES NULL parent
tms timestamp NO Current date Date of last modification. See page Field Tms.
datec datetime YES NULL creation date
datea datetime YES NULL activation date
code_client varchar(15) YES UNI NULL client code
code_fournisseur varchar(15) YES NULL supplier code
code_compta varchar(15) YES NULL accounting client code
code_compta_fournisseur varchar(15) YES NULL accounting supplier code
adress varchar(255) YES NULL company adresse
cp varchar(10) YES NULL postal code
ville varchar(50) YES NULL town
fk_departement int(11) YES 0 ID of departement (llx_c_departements->rowid)
fk_pays int(11) YES 0 ID of country (llx_c_pays->rowid)
tel varchar(20) YES NULL phone number
fax varchar(20) YES NULL fax number
url varchar(255) YES NULL web url
email varchar(128) YES NULL email
fk_effectif int(11) YES 0 ID of workers range (llx_c_effectif->id)
fk_typent int(11) YES 0 ID of type of entity (llx_c_typent->id)
fk_forme_juridique int(11) YES 0 ID of juridical status (llx_c_forme_juridique->rowid)
siren varchar(16) YES NULL IDProf1
siret varchar(16) YES NULL IDProf2
ape varchar(16) YES NULL IDProf3
idprof4 varchar(16) YES NULL IDProf4
idprof5 varchar(16) YES NULL IDProf5
idprof6 varchar(16) YES NULL IDProf6
tva_intra varchar(20) YES NULL VAT ID
capital real YES NULL capital of society
fk_stcomm int(11) YES 0 ID of commercial status (llx_c_stcomm->id)
note text YES NULL comentary
prefix_comm varchar(5) YES UNI NULL prefix commercial
client tinyint(4) YES 0 type of client (0/1/2)
fournisseur tinyint(4) YES 0 is it a supplier third pary (0/1)?
supplier_account varchar(32) YES NULL customer account to a provider
fk_prospectlevel varchar(12) YES NULL ID of prospect level (llx_c_prospectlevel->code)
customer_bad tinyint(4) YES 0 is the costumer deadbeat (0/1)?
customer_rate real YES 0 reliability rate customer (0 to 1)?
supplier_rate real YES 0 reliability rate supplier (0 to 1)?
fk_user_creat int(11) YES MUL NULL ID of creator user (llx_user->rowid)
fk_user_modif int(11) YES MUL NULL ID of modifier user (llx_user->rowid)
remise_client real YES 0 systematic discount for the customer
mode_reglement tinyint(4) YES NULL mode of payment by default
cond_reglement tinyint(4) YES NULL payment conditions by default
tva_assuj tinyint(4) YES 1 is subject to VAT?
localtax1_assuj tinyint(4) YES 0 is subject to localtax1?
localtax2_assuj tinyint(4) YES 0 is subject to localtax2?
gencod varchar(255) YES NULL bar code
price_level tinyint(4) YES NULL level of price for multiprices
default_lang varchar(6) YES NULL default language for this thirdparty
import_key varchar(14) YES NULL Code used to save the import id. See page Field Import key.
Keys
Key Type Fields
PRIMARY PRIMARY rowid
uk_societe_prefix_comm UNIQUE prefix_comm,entity
uk_societe_code_client UNIQUE code_client,entity
idx_societe_user_creat MULTIPLE fk_user_creat
idx_societe_user_modif MULTIPLE fk_user_modif
Note
  Third parties can be:
  • suppliers or customers companies (depending on the sub-elements defined) or both.
  • A normal person.
  • A foundation.
  Un tiers peut être:
  • une entreprises cliente ou fournisseur (ou les deux)
  • une personne physique
  • une association/fondation
  Un tercero puede ser:
  • una empresa cliente o proveedor (o los dos)
  • una persona física
  • una asociación/fundación
