Module Concat PDF
| Module name | |
| Editor / Editeur | NLTechno (www.nltechno.com) - http://www.dolistore.com/ |
Dolibarr min version: 3.2.0 Dolibarr max version: {{{maxversion}}} |
| Last update date / Date mise à jour fiche / Fecha última actualización | 2012-06-11 |
| Note / Nota |
Allow to merge some PDF documents to the generated PDF files. For examle, to add you conditions and terms into the PDF of an order, or to add a catalog of product into commercial proposals PDFs.
Prerequisites
Dolibarr 3.2.0 or more.
Into the setup page dedicated to module, add file system paths where you store the PDF you want to include into generated documents.
Before clicking on button "Generate" to build a PDF document, select your static PDF file to add. Addition is done at the end of the generated PDF.
