Module Users (developer)
Revision as of 16:01, 1 June 2012 by Simnandez (talk | contribs)
Users
Numéro/ID du module 0
Doc utilisateur du module Module Users
Doc développeur du module This page
Feature
Module Users is a mandatory module. It's the only Dolibarr module you can't disable. Its role is to manage permissions into Dolibarr, so to manage following entities:
  • Dolibarr users
  • Dolibarr user groups
Entity user
The PHP class to use to manipulate such object is file htdocs/user/class/user.class.php.
Entity group
The PHP class to use to manipulate such object is file htdocs/user/class/usergroup.class.php.
Permissions
  • ->user->user->lire
  • ->user->user->creer
  • ->user->user->password
  • ->user->user->supprimer
  • ->user->self->creer
  • ->user->self->password
  • ->user->self->export
Tables SQL
