Module Barcode
Revision as of 15:56, 1 June 2012 by Simnandez (talk | contribs)
Barcode
Numero/ID of module 55
Developer doc. of module Module Barcode (developer)
The engine available by default and supported by Dolibarr developers is php-barcode.
Eventually, you can install the program genbarcode (http://www.ashberg.de/php-barcode/download/#genbarcode) to have more format supported by this engine. You can also install new barcode generator engines (see in download area of http://www.dolibarr.org) to support more format.
  • Products management
  • Third parties management
Once the setup step is finished, you will see a new field "bar code" on some screens, depending on what you choosed for features to enhance (third party screen and/or product screen). You can then enter barcode values in such fields.
