Module development
To create a new module/addon for Dolibarr, there is several steps. This tutorial will describe you each of them to build a module to extend Dolibarr features, like one or several of the following :
  • Add new tables in database
  • Add your own menu entries
  • Add new screens to edit new tables
  • Add or remove tabs on object view (invoice, product, order, event, ...)
  • Add predefined exports for the internal export tool
  • Add new information boxes in the home page
  • Add new substitutions variables
  • Define new permissions
  • Execute code automatically triggered by a particular Dolibarr action
  • Insert your code inside Dolibarr hooks positions
  • Add your numbering module
  • Add a new document template
  • Add a new skin
etc... All those operations are possible with version 2.4 or more of Dolibarr.
Following chapters presents how to do all of this manually with an easy way. For experienced developers, a method to do this using MDA generation is also on the work. See last chapter for this.
Art.png Create your module
Create a descriptor of Module (required)
When: Required as soon as an addon is developed, whatever is its goal (except for adding a skin or a document template).
Create your module descriptor
The first step is to create a file descriptor for the module.
  • Create directory /htdocs/mymodule/core/modules. Then go into the directory dev/skeletons and copy the file modMyModule.class.php in this directory htdocs/mymodyle/core/modules.
Then change the contents of this file to replace:
  • all "modMyModule" with a value which corresponds to the vocation of your module. This value must always start with 'mod' and contains only alpha characters.
  • $this->numero = 10000 by a number of free module (Go to Home page -> System Information -> Dolibarr -> Modules to know id already used by existing modules).
  • Modify any other variables defined in the constructor (see comment in the code skeleton for their meaning).
Test your descriptor
Launch Dolibarr and go to page Setup->module? You must see a new line with your new module and the possibility to activate it or not (browse all the tabs of each category of modules to find it). It's value of $this->special that determines in which tab will be your module.
Tree of path for new module files (required)
Create a directory 'mymodule' that will receive all files of your module. This directory must be inside the htdocs directory and will contains following subdirectories (only first line is mandatory):
  • htdocs/mymodule/core/modules/ contains module descriptor file modMyModule.class.php
  • htdocs/mymodule/core/triggers contains triggers provided by module
  • htdocs/mymodule/admin/ contains pages to setup module
  • htdocs/mymodule/class/ contains PHP class files provided by module
  • htdocs/mymodule/css contains CSS files provided by module
  • htdocs/mymodule/img contains images files provided by module
  • htdocs/mymodule/langs/xx_XX contains language files for language xx_XX (try to put at least en_US)
  • htdocs/mymodule/lib contains libraries provided and used by module
  • htdocs/mymodule/sql contains SQL file provided by module to add new tables or indexes
  • htdocs/mymodule/themes/mytheme if module provide its own theme/skin
  • htdocs/mymodule/* contains main php pages (note that you can also add subdir here to store your main php pages)
  • build/ can contains any data file used for compiling or building package
  • docs/ contains any documentation. This directory can also contains licence files.
  • scripts/ contains any command line scripts files.
  • test/ contains any files for unit tests (data, scripts and class)
  • README.txt is a file that contains introduction about module. More precise documentation must be into docs directory.
Create your SQL tables and the PHP DAO class (optional)
Create your .sql file
by
Rules to follow:
  • Add the files about creating tables commands on the principle of a file llx_matable.sql per table with a possibly file llx_matable.key.sql (see existing files in install/mysql/tables for examples).
  • To manage data, you must create a file called data.sql inside directory /mymodule/sql/ that contains SQL command to add/edit/delete datas.
Test your .sql files
Once the files ready, you can return to Dolibarr to disable the module, dropper tables in database and reactivate the module. The tables should be recreated by the activation of the module. If this is not the case, check your scripts by passing them by hand, or check the Dolibarr logs.
Generate the PHP DAO class
The tab management (optional)
Add or removed your own tabs on object sheets
When: To add a tab on an object (invoices, orders, proposals, member ...)
	$this->tabs = array('objecttype:+tabname1:Title1:@mymodule:/mymodule/mynewtab1.php?id=__ID__',  // To add a new tab identified by code tabname1
                            'objecttype:+tabname2:Title2:@mymodule:/mymodule/mynewtab2.php?id=__ID__',  // To add another new tab identified by code tabname2
The table should contain a list of strings, each string representing a new tab. The format of the string consisting of 5 parts separated by ":"
  • Part 1: The element type (objecttype) where should the tab appears is a value from the following:
    • 'thirdparty' to add a tab in third party view
    • 'intervention' to add a tab in intervention view
    • 'order_supplier' to add a tab in supplier order view
    • 'invoice_supplier' to add a tab in supplier invoice view
    • 'invoice' to add a tab in customer invoice view
    • 'order' to add a tab in customer order view
    • 'product' to add a tab in product view
    • 'stock' to add a tab in stock view
    • 'propal' to add a tab in propal view
    • 'member' to add a tab in fundation member view
    • 'contract' to add a tab in contract view
    • 'user' to add a tab in user view
    • 'group' to add a tab in group view
    • 'contact' to add a tab in contact view
    • 'categories_x' to add a tab in category view (replace 'x' by type of category (0=product, 1=supplier, 2=customer, 3=member)
  • Part 2: A code to identify tab to add (start with +) or to remove (start with -)
  • Part 3: The title of the tab. This can be a hard read or better code translation in a file lang.
  • Part 4: The name of the file. Lang which contains correspondence between the code translation and language to display. If this name start with @, Dolibarr will search translation file into the lang file of module, so htdocs/mymodule/langs/code_CODE/mymodule.lang, otherwise Dolibarr will look for file htdocs/langs/code_CODE/mymodyle.lang
  • Part 5: The url of the page to display when you click on the tab. The __ID__ string will be replaced automatically by the Id of the element concerned.
Show tabs navigation into your own pages
When: To show all standard tabs of an object (produit, tiers, etc.) on your page.
You must follow these steps :
1. Include files you need into your file
For each pbject type, there is two files to include with line
require_once($url_fichier) ;
This is list of those files to include (DOL_DOCUMENT_ROOT is often dolibarr/htdocs/) :
  • Object thirdparty (thirdparty) :
  • Object product (product) :
  • Object invoice (invoice) :
2. Create and load the object to show into your tab
Create instance of object of the correct class and load object from database by using the fetch method of object en providing to this method the id you get from url (ie : /mytab.php?id=1).
Example :
$id=$_GET["id"];
$product = new Product($db) ;
$result = $product->fetch($id) ; //Test $result to check the database read is ok
3. Get list of all tabs to show for your object type
Use fonction XXX_prepare_head($obj), where XXX is name of object. This will return an array with all definition of tab entries to show. Parameter to put into this method is the instance of object you want tabs.
The resulting array has the following structure
$head        // Array of tabs
$head[$h][1] // Title of tab
Example :
$head = product_prepare_head($product, $user) ; // parameter $user is present for some function anly
4. show tabs into your page
Use function dol_fiche_head() to show all tabs defined into array $head returned by XX_prepare_head().
//$notab
//            product
//            service
//            company
This function will show required tabs and open an html element < div class="" > that correspond to the area under the tabs. To close area of a tab, just use < /div > into your PHP page.
Create your own PHP screens (optional)
When: If the purpose of your module is to add features that require new screens.
Create a PHP screen
To create a new user screen, create a subdirectory of htdocs (if not already done) for your module (in htdocs/monmodule for example) to store the pages you will create.
Copy, into that directory, the file skeletons_page.php that will serve as a starting point for your page file. Edit the file to have a correct relative path to the main.inc.php file.
This depends on the depth of the directory in which the file is (Add or remove "../"). It's in the main.inc.php file that is loaded technical environment variables and permissions. The following variables are objects positioned in this file:
  • $user Objet that contains the characteristics of the user + his permissions.
  • $conf Objet that contains Dolibarr configuration.
  • $db Objet that contains an opened connection handler to the database.
  • $langs Objet that contains the user's language.
Replace templated parts of screen (version 3.3+)
Some parts of Dolibarr screen are isolated into native PHP template files. You can develop a module to overwrite such templates with yours.
Database access
To read:
if ($resql)
	$num = $db->num_rows($resql);
	$i = 0;
	if ($num)
		while ($i < $num)
			if ($obj)
				// You can use here results
				print $obj->field1;
				print $obj->field2;
			$i++;
Define style of your pages
You can use for example:
Use the Dolibarr date picker
 $form=new Form($db);
Add your own setup page (optional)
When: If your module need to ask user several parameters.
If your module need several parameters to be setup, you must create a page to edit options (that will be saved into table llx_const). Create a page named mymodule_setuppage.php that show possibles options and update them into table from a form. It is a necessary to take an example from a page into directory /admin that will show you the way to read/save your parameter. Put this page into directory /admin. Then, into the descriptor file of your module, modify the variable config_page_url to set name of this PHP page (without the path that is not necesary if page is inside directory admin).
Test your page
Go into page Home->Setup->Modules, you should see a picture at the end of the line of your module to reach your setup page. Click on it, you should be able to view/edit parameters from your page.
Define your entries in menu (optional)
Define your menu entries
// Main menu entries
$r=0;
			'titre'=>'MyModule top menu',
			'mainmenu'=>'mymodule',
			'position'=>100,
			'target'=>'',
$r++;
			'position'=>100,
			'target'=>'',
$r++;
Test your menu entries
Add your own permissions (optional)
$this->rights[$r][0] = 10001;
$this->rights[$r][3] = 1;
$r++;
Define you own box (optional)
Define your box
For this, modify the array $this->boxes into the module descriptor file. All you have to do is to add one line for each box file you will create into directory htdocs/includes/boxes
Example:
this->boxes[0][1]='mybox0.php'
this->boxes[1][1]='mybox1.php'
this->boxes[2][1]='mybox2.php'
this->boxes[n][1]='myboxn.php'
Then create files mybox0.php, mybox1.php... by copying an example from an existing box file (into directory htdocs/include/boxes).
Disable and enabled module.
Define your own export (optional)
Define export
Test your export
Define your CSS styles (optional)
Create a style sheet CSS named mymodule.css and put it into directory htdocs/mymodule. You can have only one CSS file per module. Remember it's better to use existing styles already available by default into Dolibarr (The CSS file used by Dolibarr is file themes/mytheme/themename.php.css. Create your own CSS file only if you need absolutely to add not already existing styles. Once your style sheet is ready, declare it into your module descriptor file by modifying the property $this->style_sheet. Value to put here must be a relative URL to your CSS file. For example '/mymodule/myfile.css'.
Test your style sheet
You should see into the HTML header, a line that declare your style sheet.
Add your Javascript functions (optional)
If you need to use your own javascript functions inside your PHP pages, it is necessary to have your functions, defined into your javascript file htdocs/mymodule/js/mymodule.js, included into the HTML HEAD section. To ask Dolibarr that forge this header to include your own javascript file, you must just provide it to the llxHeader() function called by your page.
Example for page /htdocs/mymodule/mypage.php :
require('../main.inc.php');
Run your own code on any Dolibarr event (optional)
Insert your code inside Dolibarr hooks positions (optional)
When: When you want to add code or replace Dolibarr code into another situation than a business event (See previous chapter for adding code during a business event).
See page Hooks_system.
Add your own numbering rules
When: When you need a new rule for generated ref of elements that is not covered by existing rules.
See page Create numbering module.
Add your document template (optional)
When: When you want to personalized your own generated PDF or ODT documents.
Note: To add this feature you don't need to create a module descriptor.
Documentation to add your own template is available on page Create_a_PDF_document_template or Create_an_ODT_document_template.
Add your skin (optional)
When: When you want to personalized your colors/fonts/images.
To add your own skin, read page Skins.
Art.png Some coding rules and predefined functions
A lot of predefined features for developers are also available and described into page Developer documentation under section "Technical components of Dolibarr".
Art.png Using MDA
Art.png Create a package to distribute and install your module
This process must be used to generate a package to submit it on the http://www.dolistore.com market place. But you can use it to have a package easy to distribute on your on network.
  • Go into the directory /build and copy the file makepack-dolibarrmodules.conf into makepack-mymodule.conf. Warning, this directory may not be provided in some packages of stable versions. If so, it can be retrieved from the snapshot available for download on the Dolibarr website in area "Development version" (taken in this case the whole build directory which is autonomous and independent directory).
The script asks you the name of your module, its major and minor version. A file mymodule.zip will then be manufactured containing your module ready to be deployed.
tar -xvf mymodule.zip
  • If you want your module to be public, you can submit it (the zip file) on Dolibarr web site on download area: DoliStore.com (you must create an account first and be logged to use the link "Submit a product").
