Template:TemplateModuleTree
Revision as of 16:25, 6 April 2012 by Eldy (talk | contribs) (Created page with "* htdocs/mymodule/core/modules/ contains module descriptor file modMyModule.class.php * htdocs/mymodule/core/triggers contains triggers provided by module * htdocs/mymodule/admin...")
  • htdocs/mymodule/core/modules/ contains module descriptor file modMyModule.class.php
  • htdocs/mymodule/core/triggers contains triggers provided by module
  • htdocs/mymodule/admin/ contains pages to setup module
  • htdocs/mymodule/class/ contains PHP class files provided by module
  • htdocs/mymodule/css contains CSS files provided by module
  • htdocs/mymodule/img contains images files provided by module
  • htdocs/mymodule/langs/xx_XX contains language files for language xx_XX (en_US is required)
  • htdocs/mymodule/lib contains libraries provided and used by module
  • htdocs/mymodule/sql contains SQL file provided by module to add new tables or indexes
  • htdocs/mymodule/themes/mytheme if module provide its own skin
  • build/ can contains any data file used for compiling or building package
  • docs/ contains any documentation
  • scripts/ contains any command line scripts files.
