Prerequisites
Revision as of 16:10, 14 March 2012 by Eldy (talk | contribs) (→‎PHP)
Dolibarr was build to work on following components :
OS
  • Every OS are supported.
For example: Linux, BSD, Windows, MacOS, Aix, ...
Database
  • Mysql 5.7.7+
If using option mode=STRICT returns some warnings or error, please report them to us.
  • PostgresSql 9.1.0+
  • MSSql (experimental support not working yet)
PHP
  • Version 7.1.0+
  • Support of user sessions must be enabled (it is the default value in all PHP)
  • Works whatever is the parameter register_globals
  • Works whatever is the parameter magick_quotes
  • Works whatever is the parameter safe_mode
  • PHP configuration must allow use of a max of 128MbMb of memory (parameter PHP max_memory).
