Create a Dolibarr local community
This page is dedicated to list the guide line to help local user groups to build their own community around Dolibarr project.
Things required
All following things are required to start to be a local community. Please do all of this is same order than povided:
1) You must be a local foundation or a local company.
2) Add you company name or your foundation name to the following pages: List_of_Dolibarr_users
3) If you are a company, you must also add your name into the category "Other partners" for your country on the page: [[1]]
4) Create a page for your personnal name (not for your company or foundation) on this wiki. For this, just create an account on this wiki, login and change URL of page Laurent_Destailleur with your own firstname and lastname, then click on button "Create". You can make a copy and pate of page Laurent_Destailleur and replace with your own personnal information. The goal of this is to have a card of you and provide information on all Dolibarr actors.
5) The translation for the language of your country must be completed and accurate. If not, this is the next step. So send us translations at contact@dolibarr.org (See also page Translator_documentation to know how to fix the translation manually with the firefox plugin).
6) The setup for your country must be complete (list of vat rates, list of states). If not, send us SQL requests to have setup complete into Dolibarr sources installer (See all files into htdocs\install\mysql\data, complete them for your country and send them to us at contact@dolibarr.org).
7) Create a dedicated web site for your country called the "Dolibarr XXX portal" where XXX is your country. You can use tool of your choice for that. We recommand however Joomla as it is CMS used for other existing Dolibarr portals.
8) Put on top of your "Dolibarr XXX portal", a link with flags to others majors communities (for the moment, link to internationnal web site http://www.dolibarr.org, french portal http://www.dolibarr.fr and spanish portal http://www.dolibarr.es).
9) If you are a foundation, install Dolibarr to manage your members and create a generic account for internationnal foundation and sent it to contact@dolibarr.org (you will probably start with only two or three members, we started like this too !).
Once all this step are done, you work on next chapter.
Things recommanded
1) Translate the svg file used to create rollups for your language. You can then use it to generated a jpg file to buy a rollup to use into congres, forums, trade show or put it into show rooms.
2) Post a lot of news onto local web sites, magazines for your country (the more you promote Dolibarr, the more you will get new users, so new partners or customers). When such news appears on a major media, tell us (contact@dolibarr.org).
3) It will also be a good thing if you are yourself a member of internationnal Dolibarr foundation. See page Subscribe.
4) When all things into chapter "Things required" are completed, you may also apply to be a Preferred Partner. See Dolibarr Preferred Partner.
Things allowed
- Use Dolibarr logo on web site
Things forbidden
