Module AWStats
Module name
Last update date / Date mise à jour fiche / Fecha última actualización 2011-03-30
Add, into Dolibarr ERP/CRM software, a new menu entry to screens to read statistics compiled with AWStats log analyzer.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
