Module AWStats
Revision as of 13:31, 22 February 2011 by Eldy (talk | contribs) (→‎Informations)
Module name
Dolibarr min version: 2.6.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2011-02-22
Add, into Dolibarr ERP/CRM software, a new menu entry to screens to read statistics compiled with AWStats log analyzer.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
