Table llx prelevement facture
Presentation
Liste des factures relative à un bon de prelevement
Modules
Structure
- rowid identifiant
- fk_facture identifiant de la facture
- fk_prelevement identifiant du prélèvement
- statut statut de la ligne
-- =================================================================== -- Copyright (C) 2005 Rodolphe Quiedeville <rodolphe@quiedeville.org> -- -- This program is free software; you can redistribute it and/or modify -- it under the terms of the GNU General Public License as published by -- the Free Software Foundation; either version 2 of the License, or -- (at your option) any later version. -- -- This program is distributed in the hope that it will be useful, -- but WITHOUT ANY WARRANTY; without even the implied warranty of -- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -- GNU General Public License for more details. -- -- You should have received a copy of the GNU General Public License -- along with this program; if not, write to the Free Software -- Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. -- -- $Id: llx_prelevement_facture.sql,v 1.2 2005/01/07 13:43:42 rodolphe Exp $ -- $Source: /cvsroot/dolibarr/dolibarr/mysql/tables/llx_prelevement_facture.sql,v $ -- =================================================================== -- -- create table llx_prelevement_facture ( rowid integer AUTO_INCREMENT PRIMARY KEY, fk_facture integer NOT NULL, fk_prelevement integer NOT NULL, statut smallint DEFAULT 0 )type=innodb;
