Module Suppliers (developer)
Supplier
Numero/ID of module 40
User doc. of module Module Suppliers Orders,
Module Suppliers Invoices
Feature
This module manage the following entities:
  • Suppliers orders
  • Lines of suppliers orders
  • Suppliers invoices
  • Lines of suppliers invoices
Entity Supplier orders
The PHP class to use to manipulate such object is file htdocs/fourn/class/fournisseur.commande.class.php.
Business rules
See Module Suppliers Orders.
Permissions
  • ->fournisseur->commande->lire
  • ->fournisseur->commande->creer
  • ->fournisseur->commande->valider
  • ->fournisseur->commande->approuver
  • ->fournisseur->commande->commander
  • ->fournisseur->commande->cloturer
Different Status
Number is value of field fk_statut in Table llx_commande_fournisseur.
  • 0 : draft
  • 1 : validated (no more a draft)
  • 2 : accepted (Your leader accept your request)
  • 3 : sent to supplier
  • 4 : received partially
  • 5 : received completely or closed
  • 9 : refused (Your leader disagree your request)
Entity Supplier invoices
The PHP class to use to manipulate such object is file htdocs/fourn/fournisseur.facture.class.php.
Business rules
See Module Suppliers Invoices.
Life cycle
Permissions
  • ->fournisseur->facture->lire
  • ->fournisseur->facture->creer
  • ->fournisseur->facture->valider
  • ->fournisseur->facture->supprimer
  • ->fournisseur->facture->export
Tables SQL
