Environment and development tools
Every integrated development environment can be used. However, this is a list of tools highly recommanded to use. They are all famous and a good help as they are featurful and of high quality. They are used by most main Dolibarr developers. Above all, they are all free and Opensource.
For every developer
This is the recommended main tools but every tool compliant to Web, PHP, Mysql and Web standards can be used.
An AMP server
- Apache, Mysql and PHP
For Linux: Those 3 products are available in all Linux distribution by default.
For Windows: Install WampServer 2 (Mysql database, Apache and PHP in an all in one package). This WAMP server offers MySql+Apache+PHP, with possibility to change version of any of this component with a simple click.
Firefox and plugins
- Firefox 3.0 with plugins:
- HTML Validator,
- Phplangeditor and Dictionnaries of any languages you plan to translate,
- Firebug + Firecookie,
- Cert Viewer Plus if you plan to make tests with HTTPS,
- FoxyProxy if you want to switch quickly on proxy tools (WebScarab),
- User Agent Switcher to simulate usage of smartphones.
You can download this on web site http://www.firefox.com
SquirrelSQL
- SquirrelSQL for database administration
You can download it at http://squirrel-sql.sf.net
Eclipse and plugins
Install Eclipse
We recommend to use the following package of Eclipse: https://eclipse.org/pdt/
Also any version available on Eclipse we site is possible.
Install plugin Eclipse for PHP: PDT.
If you installed Eclipse version defined previously, all you have to do is using process Help -> Install new software -> Add -> Archive to add module:
Setup Eclipse to get CVS version
Once Eclipse is installed, you can connect to CVS repository to get last development version.
- Create a new project: File >> New >> Projects then select "Project from CVS" and "Next"
- Select "Create a new repository location" then "Next"
- Fill the windows like this:
- Then fill the field Use specified module name : dolibarr
- Choose the name of project on you computer :
- Check out as a projet in the workspace
- Project Name : dolibarr
- Checkout subfolders
- Then, keep default path of workspace and click "Next"
- Then, select the branch to load
- HEAD is development version
- Versions 2.6, 2.6, etc., are into Branches
- Click "Finish"
Files should be download on your hard disk.
Then to update your local version, you must switch to "Team Synchronizing" to use the feature "Synchronize CVS", this will download latest versions on your hard disk. Only remotely modified files will be downloaded again.
Optional
If you manage other projects with SVN
- Install Eclipse plugin for SVN: SubClipse
For this, use the Find And Install process and add the SVN update URL:
http://subclipse.tigris.org/install.html
or
- Install Eclispe plugin for SVN: Subversive
http://community.polarion.com/projects/subversive/download/eclipse/2.0/ganymede-site/ - [required] Subversive SVN Connectors http://community.polarion.com/projects/subversive/download/integrations/ganymede-site/ - [optional] Subversive Integrations
If you want to make Perl scripts
- Install the Eclipse plugin for Perl: EPIC
For this, use the Find And Install process and add the update URL: http://e-p-i-c.sourceforge.net/updates
If you want to develop modules with the UML2Dolibarr generator
A method to generate code of a module from UML is currently on work. More information on page Building a module using MDA. To use it, you must install the following components (If you install the previously recommanded version of Eclipse, all of this is already done):
- Install TopCased 1.4+: http://www.topcased.org
- Install Acceleo 2.2.1+
For this, user menu Find And Install and add update URL: http://www.acceleo.org/update/
- Install UML2Dolibarr
For this, get the procject with command:
svn checkout svn://svn.forge.objectweb.org/svnroot/acceleo/trunk/modules/community/uml21/dolibarr/trunk/and import it into Eclipse.
If you are using Windows
- Notepad++ (for those which can't stand java or using a computer too old for Eclipse).
- WinMerge (to compare files and directories)
- CygWin (to have the "patch" command and the command line CVS if you prefer command lines interface)
If you want to make step by step debugging or tunning (XDebug)
- To add global tuning information for pages on your browser status bar, add environment variable DOL_TUNING to 1 into Apache. For this, just add the following line into your apache.conf:
SetEnv DOL_TUNING 1
Then, check that your browser does not have options to block changing of status bar by javascript.
- Install XDebug.
With Ubuntu: install package php-xdebug
With WampServer/Windows: Download dll file on http://www.xdebug.org and to store in directory ext of php. Then enable plugin.
- Modify php.ini file (or xdebug.ini) to add parameters:
[xdebug]
xdebug.remote_enable=on
xdebug.remote_handle=dbgp
xdebug.remote_host=localhost
xdebug.remote_port=9000
xdebug.profiler_enable=1
xdebug.show_local_vars=off
xdebug.profiler_append=0
- Then to analyze files generated by XDebug profiling, you can install KCacheGrind (Linux) or WinCacheGrind (Windows).
To develop or use PHPUnit test
From Eclipse
You can also optionnally install The PHP Tools integration for Eclipse:
http://www.phpsrc.org/eclipse/pti/
If you do so, menu to launch PHPUnit tests are available in your Eclipse menu. If not, you must install and run PHPUnit manually from command line.
From Command Line
Instal PHPUnit
- Download a release archive from http://pear.phpunit.de/get/ and extract it to a directory that is listed in the include_path of your php.ini configuration file.
- Prepare the phpunit script:
- For Linux: Rename the phpunit.php script to phpunit and replace the @php_bin@ string in it with the path to your PHP command-line interpreter (usually /usr/bin/php).
- For Windows: Replace the @php_bin@ string in file phpunit.bat with the path of your PHP command-line interpreter and @bin_dir@ string with the path of the PHPunit directory.
- Edit your Path to inclulde PHPunit directory
- Make script runnable (chmod +x phpunit on Linux).
- Prepare the PHPUnit/Util/PHP.php script:
- Replace the @php_bin@ string if it exists in file it with the path to your PHP command-line interpreter (usually /usr/bin/php).
- Module xdebug can also be required if you plan to make reporting of test code covering.
Execute PHPUnit tests
- Go into directory /test of CVS version. Read file README to know the process to execute a unit test campaign.
To develop or use Selenium tests
From Firefox
Install plugin for Firefox Selenium IDE
- Download file of plugin "Selenium IDE" for Firefox.
- Add it into firefox in menu Tools - Complementary modules.
Execute Selenium tests
- Go into menu Tools - Selinum IDE of Firefox.
- Open xml file of the suite tests.
- Execute the test.
CVS Setup
If you are an official developer with a write CVS access, add into your Eclipse setup a CVS entry.
- :ext:yourlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr for main Dolibarr project.
- :ext:yourlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarrmod for secondary external modules.
Otherwise, you must get sources from tarball available on Dolibarr web site ( http://www.dolibarr.org ) in download area.
