Module AWStats
Revision as of 10:59, 18 August 2010 by Eldy (talk | contribs) (→‎Features)
Module name
Dolibarr min version: 2.6.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2010-08-18
Add, into Dolibarr ERP/CRM software, a new menu entry to screens to read statistics compiled with AWStats log analyzer.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
