Module AWStats
Module name | |
Editor / Editeur | NLTechno (www.nltechno.com) - http://www.dolistore.com/ |
Prerequisites / Prérequis |
Dolibarr min version: 2.6.0 Dolibarr max version: {{{maxversion}}} |
Last update date / Date mise à jour fiche / Fecha última actualización | 2010-08-10 |
Note / Nota |
Add, into menu, screens to read statistics compiled with AWStats log analyzer.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
