Developer FAQ
This page contains some frequently asked questions related to Dolibarr development. For frequently asked questions on other topics, read page User FAQ.
How to be an official developer
In the galaxy of the Dolibarr project, there are several actors with different levels / grades. The number of developers is important so contributions and changes, for any project that wants to reach a certain level of quality, must be controlled and validated (both for functional needs and for coding). For this reason, the write access on the source (CVS) is limited and governed by an organization that is described in the following. Each developer has a grade depending on seniority and the past. The level of authorization of a person on the project increases with the stages of promotion in grade.
The course of a Dolibarr developer passes through these steps, which are classified by a title familiar to fans of science fiction. Here are the steps. It is important to understand that this organization has the sole purpose of improving the quality of Dolibarr and it is necessary that it is rigorously used. So do not be offended if, as a developer, you can not have a CVS write access for some time.
The ranks of contributors to the Dolibarr project are:
* Soldier
The first thing that a person willing to help is to be familiar with the rules and standards developments. By reading the Developer documentation, you have shown sufficient willingness to become automatically Soldier (grade level Soldier). Most people that are interesting in Dolibarr development are in this cateogry.
This grade is obtained without validation higher. It is a grade of principle, to start.
Due to the nature of this level, it is not possible to establish a list of all Dolibarr actors with this grade (list always changing and too long).
* Fighter
The next step is to submit your first patch, starting with simple ones, on the dev Mailing List (see chapter Submit a patch, work and help on Dolibarr development for the procedure) or on the forum (Preferred Mailing List).
You can find easy to do patches on the todo tracker: http://savannah.nongnu.org/task/?group=dolibarr
Easy to start tasks are task with property "Task opened to external developers" that is set to "yes". If value is "no", forget it, this means task will be processed by a developer with grade Jedi.
At your first accepted patch (included in CVS by an Admiral, Jedi or Yoda), you automatically enter into the family of Fighters of the Dolibarr alliance.
The number of hunters is not limited. The more we are, the more we will be strong. The hunters are the main force of the alliance Dolibarr.
A list of Dolibarr contributors with this grade is available on page Category:Chasseur
* Z-6PO
If you are fluent in a language not or poorly translated into Dolibarr, a Jedi or Yoda will grant CVS access to your Savannah login, so you can make changes and commits directly into the CVS of the project.
Go on http://savannah.nongnu.org to create an account and claim to be part of project as a Z-6PO for your language.
You can also read page Get/update the development CVS version to know how to use the CVS server to commit your changes on language files. But commits must be limited to changes for translations purposes. This grade can be obtained quickly enough. Just ask it on mailing list.
A list of Dolibarr contributors with this grade is available on page Category:Z-6PO
* Admiral
Only after a variable time (which can be very long) to the rank of a Fighter, and many patches of suitable quality had been sent, a Yoda in place allows you to make CVS commits extended for cause of any patch. You have become an Admiral of the Dolibarr alliance.
This title can't be asked, it is obtained by a decision or proposal of a Jedi or Yoda who believes that you have submitted enough patch to be a serious Admiral. An Admiral CVS access, however, must be used to commit translations or bug fixes reported on Savannah or forum (such as personal fixes or fixes submitted by a Fighter). So all CVS commits you do must necessarily include in the description (the commit log field), the issue of Savannah bug corrected or the title of the forum message indicating the problem. Only a translation escapes this constraint (no restrictions for translations). Failure to observe this constraint may lead to downgrade to the rank of Fighter. For submission of new features, an Admiral must necessarily proceed on the principle of patches sent to the ML.
Obtaining the rank of Admiral is as rare as limited. Dolibarr quality can not be achieved without a limited number of Admirals, but this is still compatible with having a very high number of developers (Fighters), contributing through patches.
A list of Dolibarr contributors with this grade is available on page Category:Admiral
* Jedi
This is even after a variable time (probably the longest of all) to the rank of Admiral, and the quality of the patch that was sent is satisfactory, that a Yoda will tell you that you are authorized to perform commits without restrictions, included new features, however you will still have to explain to all Yoda what you want to do to give back a "go". You will then become a Jedi. There may be temporary restrictions on commits, defined by a Yoda, for example due to a close release.
This title can't be asked, it is obtained by a proposal of another Jedi or by a Yoda.
This privilege is exceptional. Dolibarr quality can not be achieved without a limited number of Jedi, but this is not compatible with a high number developers (Fighters) contributing with patches.
A list of Dolibarr contributors with this grade is available on page Category:Jedi
* Yoda
There is about 1 to 5 Yoda. It's the overall management of project development. This ranking is obtained by inheritance or vote, for example it can be after a vote organized by a Yoda making retirement.
A list of Dolibarr contributors with this grade is available on page Category:Yoda
* And Darth Vader?
There is some parasites people that pollute the forum or mailing-list with aggressive messages, which slows the development of Dolibarr rather than offering constructive criticism to help improve. Some are very strong bad liver and bad tone. Such people are Darth Vaders. Fortunately, statistically, there is only one or two Dark Vador per year ...
Current team
See page Dolibarr Project to know list of current people that work on Dolibarr, with their current grade.
Start a development
Read first completely the Developer documentation to know all rules a developer must respect. You can also read following FAQ.
Get/update project sources
This is informations on how you can get sources of Dolibar project.
Get last version of sources using a CVS anonymous access
With no Savannah account or no CVS write privileges, you can still get files with a CVS client (WinCVS or TortoiseCVS for example with Windows, or the CVS client in Eclipse).
The command to get a full snapshot in working directory is:
CVSROOT=:pserver:anonymous@cvs.savannah.nongnu.org:/cvsroot/dolibarr
export CVSROOT
cvs -q checkout -r HEAD dolibarr
HEAD means we want last version of files (so last development files).
Get last version of sources using a full CVS access
Another way to get last CVS version is to use CVS tools. You need a Savannah write CVS access to CVS repository and a CVS client (CVS command line tool with Linux, WinCVS or TortoiseCVS for example with Windows, or the CVS client in Eclipse).
The command to get a full snapshot in a working directory is:
CVSROOT=:ext:yoursavannahlogin@cvs.savannah.nongnu.org:/cvsroot/dolibarr
export CVSROOT
Get complementary modules
A CVS repository for non official or rare Dolibarr modules is also available into CVS module dolibarrmod
export CVSROOT
cvs -q checkout -r HEAD dolibarrmod
Update your repository
The command to update files that was caught with previous CVS command:
With linux:
cvs -q update -P -d
With Windows and Tortoise cvs
And to set back all your working directory with same files than on CVS server repository (canceling your local changes):
With linux:
cvs -q update -P -C -d
May be, you will have to change permissions on directories or files after to make then readable by users of your Dolibarr web server.
Get files for a particular CVS branch
If you want to work on a particular version (with its patches), you must follow same process but you must replace HEAD by name of the branch. For example DOLIBARR_2_2_BRANCH for branch 2.2 or DOLIBARR_2_4_BRANCH for branch 2.4.
Get last version of sources by download
This method allows you to get CVS version of main development branch (called HEAD). This operation consist to get last version of Dolibarr files that are packaged each night into a zip file. For this, go on page with last CVS version of the day.
New files will overwrite old ones. The inconvenient of this method is that you must download and uncompress again all archive file to get updates.
Update database
If you make an update of sources, the next step is to upgrade your database to reflect new sources. For this, all you have to do is call page http://myrootdolibarr/install/ and choose option "Update".
This process was built to work whatever is start step and can be run and rerun several times with no risks.
How to create a new skin
For this, see page Skins
For this, see page Menus system
How to develop my own module
To develop your own numbering module, see Create numeration module.
To develop your own document model, PDF or other, see Create document model.
To develop your own business module (screens, tables), see page Module development.
How to add/complete a translation
For this, see page Translator documentation
Change my numbering system after start
If the new numbering system does not conflict with the old one, to change the numbering rule, just go on menu Setup - Modules - Invoice setup and choose the new numbering rule in the list. If the new rule can crete conflicts with old one, it will be necessary to rename old existing references. This can be do by a SQL request. For example, to go from numbering module Jupiter (FYYYYMM99) to Terre (FAYYMM-999), you can run the folloing request:
For example, to rename references from modele FAYYMM999 to Terre (FAYYMM-999), you can ru the following request:
If you want to know what you can do to start or help Dolibarr development, read instead chapter Developer_FAQ#How_to_be_an_official_developer. If you already read it and want to distribute a patch, this chapter is for you.
- With a CVS write access
For the moment, CVS write access are restricted (number of commits is already active). If you have this access, you can use it, but if and only if you use it to commit changes you are granted to with your developer grade (See Developer FAQ#How to be an official developer for information on different grades). If you don't have CVS access (your grade must be Soldier or Fighter), it is necessary to follow the following steps...
- With no CVS write access
With no write CVS access (with no savannah developer account), it is necessary to provide a patch file by mail.
For all OS:
This is the best method to work to build such a patch file:
- First, you must have a directory containing last reference version of Dolibarr (the result of a CVS update or simply the files resulting of uncompressing a dolibarr.tgz snapshot). We will cal this directory old_dir. You can get this snapshot for current developed version on Dolibarr official web site in download area - development version.
- Then, you must have a second directory, from same source, that will contains Dolibarr directories, in which you will make all you files. We will call this directory new_dir.
To build the patch file, you must launch the diff command (available on all Linux, provided with cygwin under Windows) with the following command:
diff -Naur --exclude=CVS --exclude="*.patch" --exclude=".#*" --exclude="*~" --exclude="*.rej"
--exclude="*.orig" --exclude="*.bak" --exclude=conf.php --exclude=documents
old_dir new_dir > mypatch.patch
A ksh script to run this command is available in directory build/patch. Send your patch on Dev Mailing List to the address dolibarr-dev@nongnu.org (after subscribing to it). Inclusion of your patch is however not guaranted, no more than delay. But if patch is realized strictly with using this process, there is a very important probability (near 100%) that it will be at least "tested" (if patch is not done this way, chance are simply null).
For Windows:
If you work on Windows, another method (not so nice than previous) is also possible. Install the open source compare tools called Winmerge (this tool is able to build patch with format diff -Naur). Then compare with WinMerge the reference file and modified file and choose in menu "Tools - Generate patch". Add an output filename like "mypatch.patch", click on box "Append" and hcoose option "Format Unified". Then click on "Ok". Eventually restart for each modified file. Finally, you will get a file mypatch.patch that contains all changes with goode format.
- Test/Apply a patch
If you want to apply a patch file on an old version to have a new one modified by the path file, this is possible with the patch tool. Imagine you have on non modified version somewhere on a server. Put you patch file into the root directory. Go into this root directory then launch the command:
patch -u -p0 -d . < mypatch.patch
For information: -p0 is to use full path of files defined in patch file to locate them on your disk (-pn will remove the n first levels of directories) -d define the relative path do directory to patch. < is to provide source file name to use (patch must have format previsouly defined) -u is to tell that patch has unified format
How to package and deploy a module
See page Module development
How to be informed on news and what happens on Dolibarr project ?
See page FAQ How to be informed on news about Dolibarr project ?
