Module AWStats
Module name
Editor / Editeur NLTechno - http://www.nltechno.com/
Dolibarr min version: 2.6.0    Dolibarr max version: {{{maxversion}}}
Last update date / Date mise à jour fiche / Fecha última actualización 2010-03-7
Add, into menu, screens to read statistics compiled with AWStats log analyzer.
From the application
Manually
unzip modulefile.zip
To complete
CVS repository
