Module Third Parties setup
Help on screen: Module Third parties setup
Menu path: Home -> Setup -> Modules -> Third parties -> Setup (with 'eldy' menu manager)
Module to build and control third parties codes
Choose here the module to use as a counter to define the customer code and the supplier code for new created third parties.
Module to build accountancy codes
Choose here the module to use as a counter to define automatically an accountancy code for new created third parties.
Modules to build documents
Activate here documents generation module.
Module Generic ODT
With this module, you define a list of file system path containing ODT templates files (files must end with .odt). You can use OpenOffice or any word processor able to save files with .odt format.
Then add and edit your ODT templates files with the text of documents you want to get.
Place inside this templates some tags that will be replaced at the generation process. This is full list of possible tags:
- {mycompany_name} ->
Your company name /
Nom de votre company /
Nombre de su empresa
- {mycompany_email}
- {mycompany_phone}
- {mycompany_fax}
- {mycompany_address}
- {mycompany_zip}
- {mycompany_town}
- {mycompany_country}
- {mycompany_url}
- {mycompany_barcode}
- {mycompany_vat}
- {mycompany_idprof1}
- {mycompany_idprof2}
- {mycompany_idprof3}
- {mycompany_idprof4}
- {mycompany_note}
- {company_name} ->
Third party name /
Nom du tiers /
Nombre del tercero
- {company_email}
- {company_phone}
- {company_fax}
- {company_address}
- {company_zip}
- {company_town}
- {company_country}
- {company_url}
- {company_barcode}
- {company_vat}
- {company_customercode}
- {company_suppliercode}
- {company_customeraccountancycode}
- {company_supplieraccountancycode}
- {company_idprof1}
- {company_idprof2}
- {company_idprof3}
- {company_idprof4}
- {company_note}
Other
Define or not other options.
