Module Suppliers Invoices
| Suppliers | |
| Developer doc. of module | Module Suppliers (developer) |
The module Suppliers invoices can be used to create or modify or delete invoices with lines invoices for every third party of type "supplier". This module is also used to manage payments of such invoices. The customer invoices are managed by the Module Customers Invoices.
Create invoice
Types of invoices
Currently, only standard invoices are managed for suppliers invoices.
- The "standard invoice":
This is common invoices. There are no prerequisites.
- The "replacement invoice":
Not yet managed for suppliers
- The "credit note":
- The "invoice deposit"
Procedure
Once an invoice is created (in draft mode), you must include in the invoice all products or services already defined in Dolibarr or you directly enter a title, a VAT rate, a unit price. For each line of the invoice, you also set an amount and possibly a discount (percentage).
Once your order ready you must validate it. Note this operation is irreversible. When you validate the invoice number is assigned by the numbering scheme that you chose in the configuration of the Supplier module. If an error is detected after confirming your order, you must either make a replacement bill or make an invoice have.
Enter payments
To complete...
Close invoice
To complete...
Export suppliers invoices
See the Modules Exports
Example of use cases
| UCSIN02: I received a supplier invoice then a credit note | |
| Situation | I received a supplier invoice then a credit note |
| Actions | I enter the supplier invoice (standard invoice) once received.
Then I received the credit note to correct this first invoice, so i enter an new standard invoice but with a negative amount. Once I payed, I enter the payment on standard invoice, and a negative payment on the negative invoice. I can close the two invoices as "payed". A negatif and positive amount may appear on the bank receipt. You can manually edit them to have just one if you prefer. |
