Module Suppliers Invoices
| Suppliers | |
| Developer doc. of module | Module Suppliers (developer) |
The module Suppliers invoices can be used to create or modify or delete invoices with lines invoices for every third party of type "supplier". This module is also used to manage payments of such invoices. The customer invoices are managed by the Module Customers Invoices.
Create invoice
Types of invoices
Currently, only standard invoices are managed for suppliers invoices (not credit note).
- Standard invoices:
This is common invoices. There are no prerequisites.
- Replacement invoice:
Not yet managed
- Credit note:
Not yet managed
Procedure
Once an invoice is created (in draft mode), you must include in the invoice all products or services already defined in Dolibarr or you directly enter a title, a VAT rate, a unit price. For each line of the invoice, you also set an amount and possibly a discount (percentage).
Once your order ready you must validate it. Note this operation is irreversible. When you validate the invoice number is assigned by the numbering scheme that you chose in the configuration of the Supplier module. If an error is detected after confirming your order, you must either make a replacement bill or make an invoice have.
Saisir les paiements
A compléter...
Classer la facture
A compléter...
Exporter les factures fournisseurs
Cas d'utilisations
| UCSIN02: Facturation fournisseur puis réception avoir suite erreur facture | |
| Situation | Je reçois une facture fournisseur et un avoir suite erreur facture |
| Actions | Je saisi la facture fournisseur (facture de doit).
Je reçois l'avoir fournisseur (facture avoir/note de crédit), et je saisis une facture fournisseur normale mais avec montant négatif. Je paie (Émettre paiement). Je saisi le paiement sur facture fournisseur et un paiement négatif sur facture avoir fournisseur. Je classe les deux factures comme "payées" Un paiement positif et un autre négatif pour corriger apparaitront dans le relevé bancaire. |
