Table llx facture fourn det
Content/Contenu/Contenido
En verysmall.png Contains the lines of providers invoices. This table is linked to Table llx facture fourn
Fr verysmall.png Contient les lignes des factures fournisseurs. Cette table est liée avec la Table llx facture fourn
Es verysmall.png Contiene las líneas de las facturas de proveedores. Esta tabla está vinculada con la Table llx facture fourn
Structure
Table
Version 1.1 2009/10/07
rowid int(11) NO PRI auto_increment technical index
fk_facture_fourn int(11) NO MUL ID of provider invoice (llx_facture_fourn->rowid)
fk_product int(11) YES NULL ID of product (llx_product->rowid)
ref varchar(50) YES NULL supplier ref. of product
label varchar(255) YES NULL label of product
description text YES NULL description of supplier invoice line
pu_ht double(24,8) YES NULL unit price excluding tax
pu_ttc double(24,8) YES NULL unit price with tax
qty real YES NULL quantity of product
tva_taux double(24,8) YES 0.00000000 tax
total_ht double(24,8) YES 0.00000000 total excluding tax
tva double(24,8) YES 0.00000000 vat
total_ttc double(24,8) YES 0.00000000 total with tax
product_type int(11) YES 0 type of product
date_start datetime YES NULL start date if service
date_end datetime YES NULL end date if service
import_key varchar(14) YES NULL Import key
Keys
Key Type Fields
PRIMARY PRIMARY rowid
idx_facture_fourn_det_fk_facture MULTIPLE fk_facture_fourn
