Module LDAP En
LDAP | |
Numero/ID of module | {{{num}}} |
Developer doc. of module | Module LDAP (developer) |
The LDAP module must be used if you want to synchronize somer Dolibarr entities with a LDAP database. The entities and direction you can synchronize are:
- User (Module Users) -> LDAP
- Group (Module Users) -> LDAP
- LDAP -> User (Module Users)
- Contact (Module Third parties) -> LDAP
- Member (Module Foundations) -> LDAP
Information you must supply in the LDAP module setup are:
- Choose what you want to synchronize
- LDAP server information (ip, port...)
Once datas are filled, make a test by using button "Test LDAP connection" to be sure they are correct.
- Enter the organization of your LDAP tree
- Make matching between Dolibarr fields and LDAP fields.
Once datas are filled, make a test by using button "Test synchronization" to be sure they are correct.
For synchronization from Dolibarr to LDAP, once your setup is done, there is nothing to do. Each time you make a change in Dolibarr, the change is also saved into your LDAP.
