LDAP | |
Número/ID módulo | {{{num}}} |
Doc. módulo usuario | Esta pagina |
Doc. módulo desarrollador | Module LDAP (developer) |
Introducción
The LDAP module must be used if you want to synchronize somer Dolibarr entities with a LDAP database. The entities and direction you can synchronize are:
- User (Módulo Usuarios) -> LDAP
- Group (Módulo Usuarios) -> LDAP
- LDAP -> User (Módulo Usuarios)
- Contact (Módulo Terceros) -> LDAP
- Member (Módulo Miembros) -> LDAP
Instalación
Configuración
Information you must supply in the LDAP module setup are:
- LDAP server information (ip, port...)
- Choose which synchronization you want
- Enter the organization of your LDAP tree
- Make matching between Dolibarr fields and LDAP fields.
For synchronization from Dolibarr to LDAP, once your setup is done, there is nothing to do. Each time you make a change in Dolibarr, the change is also saved into your LDAP.
