Module Google
Revision as of 23:15, 9 August 2009 by Eldy (talk | contribs) (moved Module GoogleEn to Module Google En)
Add into Dolibarr menu a new entry called "Agenda" to show contents of Google agendas.
From the application
Manually
unzip modulefile.zip
To complete
To complete
