Module Users (developer)
Users
Numéro/ID du module {{{num}}}
Doc utilisateur du module Users
Doc développeur du module This page
Feature
Module Users is a mandatory module. It's the only Dolibarr module you can't disable. Its role is to manage permissions into Dolibarr, so to manage following entities:
  • Dolibarr users
  • Dolibarr user groups
Number : 0
Entity user
The PHP class to use to manipulate such object is file htdocs/user.class.php.
Entity group
The PHP class to use to manipulate such object is file htdocs/usergroup.class.php.
Permissions
  • ->user->user->lire
  • ->user->user->creer
  • ->user->user->password
  • ->user->user->supprimer
  • ->user->self->creer
  • ->user->self->password
  • ->user->self->export
Tables SQL
  • llx_user contains llist of Dolibarr users
  • To complete...
