Module Projects
Project | |
Numéro/ID du module | {{{num}}} |
Doc développeur du module | Module Projects |
The Project module allows you to manage tasks and time consuming on tasks. You can also link Dolibarr entities to a project (like commercial proposals, des customers orders or customers invoices).
Definitions
Before starting to use the Project module, it is important to understand the difference and meanings of following terms Events / Tasks / Journals. This terms are often misunderstood and they are used differently. So you should first know the real definitions of this terms as they are used by most ERP/CRM softwares. For this, you can read definitions on page EventsTodoJournal
Create a project
Creation of a new project is done from menu "New project" on main menu "Poject"
Create a task
Creation of a task is done from a the Task tab of a project card.
Remove a project
To complete
Remove a task
To complete
Examples of use cases
To complete
