Table llx facturedet
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Content/Contenu/Contenido
Contient les lignes des factures clients, , cette table est liée avec la Table llx_facture.
Contains the lines of customer invoices, this table is linked with Table llx_facture.
Contiene las líneas de las facturas a clientes, esta tabla está vinculada con Table llx_facture.
Structure
Field | Type | Null | Key | Default | Extra | Description |
rowid | int(11) | PRI | NULL | auto_increment | technical index | |
fk_facture | int(11) | MUL | 0 | ID of facture | ||
fk_product | int(11) | YES | NULL | ID of product | ||
description | text | YES | NULL | description of customer invoice line | ||
tva_taux | double | YES | NULL | Line VAT Tax | ||
qty | double | YES | NULL | |||
remise_percent | double | YES | 0 | |||
remise | double | YES | 0 | |||
fk_remise_except | int(11) | YES | NULL | |||
subprice | double | YES | NULL | |||
total_ht | double | YES | NULL | |||
total_tva | double | YES | NULL | |||
total_ttc | double | YES | NULL | |||
date_start | datetime | YES | NULL | |||
date_end | datetime | YES | NULL | |||
info_bits | int(11) | YES | 0 | |||
fk_code_ventilation | int(11) | 0 | ||||
fk_export_compta | int(11) | 0 | ||||
rang | int(11) | YES | 0 | View Order |
