Table llx facturedet
Content/Contenu
Fr verysmall.png Contient les lignes des factures clients.
En verysmall.png Contains the lines of customer invoices.
Es verysmall.png Contiene las líneas de las facturas a clientes.
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_facture int(11) MUL 0 ID of facture
fk_product int(11) YES NULL ID of product
ref varchar(50) YES NULL supplier ref. of product
label varchar(255) YES NULL label of product
description text YES NULL description of customer invoice line
tva_taux double YES NULL Line VAT Tax
qty double YES NULL
remise_percent double YES 0
remise double YES 0
fk_remise_except int(11) YES NULL
subprice double YES NULL
total_ht double YES NULL
total_tva double YES NULL
total_ttc double YES NULL
date_start datetime YES NULL
date_end datetime YES NULL
info_bits int(11) YES 0
fk_code_ventilation int(11) 0
fk_export_compta int(11) 0
rang int(11) YES 0 View Order
