FAQ Is there an autoinstaller
Revision as of 10:42, 3 July 2009 by Eldy (talk | contribs)
Is there an autoinstaller for Windows ?
Dolibarr is a GPL OpenSource project. Like a lot of other GPL projects, what is distributed is sources. Packaging for an automatic installation is most often provided by the OS distribution you use. If you are on Linux or BSD systems, this is easy to use because there is a lot of packages can be found "ready to use", it's not so simple for Windows. However there is a solution... Because Windows does not offer software repositories ready to work nor packaging solution for external applications used by Dolibarr (Apache, PHP, MySQL), Dolibarr installation can seems difficult to do for unexperienced users.
So NLTechno provide a packaged version for Windows called DoliWamp that install Dolibarr but also all prerequisites (Apache, PHP, Mysql) with a simple .exe file.
See DoliWamp product page on NLTechno web site.
