Table llx c payment term
Revision as of 07:32, 8 June 2009 by Simnandez (talk | contribs)
Content/Contenu/Contenido
  Contains the most current payment conditions for invoices: 30 days end of month, 60 days end of month, upon receipt, proforma, etc.
  Contient les conditions de règlement de factures les plus courantes: 30 jours fin de mois, 60 jours fin de mois, à réception, proforma, etc.
  Contiene las condiciones de pago para las facturas más comunes: 30 días a fin de mes, 60 días a fin de mes, a la recepción, proforma, etc.
Structure
rowid int(11)   PRI NULL auto_increment technical index
code varchar(16) YES NULL intern code to search the translations
sortorder smallint(6) YES NULL order to view into a listbox
active tinyint(4) YES 1 1=actif, 0=inactif
libelle varchar(255) YES NULL label (name) shown on screen (although caught in the language files, so it is used only no translation are found)
libelle_facture text YES NULL label (name) shown on PDF documents (although caught in the language files, so it is used only if no translation are found)
fdm tinyint(4) YES NULL end of month (eg "30 days end of month"). 0=no, 1=yes
nbjour smallint(6) YES NULL number of days after invoice for due date
decalage smallint(6) YES NULL if end of month is used, you can also add an offset for days from the start of month for the due date
