Table llx facturedet
Revision as of 16:05, 23 May 2009 by Eldy (talk | contribs) (Created page with 'Category:Invoices Category:Facture Category:Facturas Category:Table SQL {{ListOfTables}} = Content/Contenu = {{Flag fr}} Contient les lignes des factures clien...')
Content/Contenu
  Contient les lignes des factures clients.
  Contains the lines of customer invoices.
  Contiene las líneas de las facturas a clientes.
Structure
rowid int(11)   PRI NULL auto_increment technical index
fk_facture int(11) MUL 0 ID of facture
fk_product int(11) YES NULL ID of product
description text YES NULL
tva_taux double YES NULL Line VAT Tax
qty double YES NULL
remise_percent double YES 0
remise double YES 0
fk_remise_except int(11) YES NULL
subprice double YES NULL
total_ht double YES NULL
total_tva double YES NULL
total_ttc double YES NULL
date_start datetime YES NULL
date_end datetime YES NULL
info_bits int(11) YES 0
fk_code_ventilation int(11) 0
fk_export_compta int(11) 0
rang int(11) YES 0 View Order
