Module Double Entry Accounting
Revision as of 09:50, 14 November 2015 by Eldy (talk | contribs) (Created page with "Category:Accounting {{TemplateDocUser}} {{TemplateModEN}} {{BasculeDevUser| nom=Accountancy| num=50400| devdoc=Module Accounting Advanced (developer)| userdoc=This page|...")
Accountancy
Numéro/ID du module 50400
Doc développeur du module Module Accounting Advanced (developer)
The Accounting Advanced module provide double entry accounting features.
Life cycle / Business rules
Examples of use cases
UCAC01:
Situation
Actions
