Triggers system
Execute your own code on a Dolibarr business event
Note that triggers is a feature for developers that is limited to business CRUD events (Create | Read | Update | Delete). There is another feature for developers to inject custom code in the application called the Hooks system.
So, to add your own code that will be triggered by a Dolibarr trigger, this is the process:
- interface_99_all_Xxx.class.php
or
- interface_99_modMyModule_Xxx.class.php
Note: Value you can use for mod MyModule are values found in directory htdocs/includes/modules.
For example, you can name your new trigger file: htdocs/includes/triggers/interface_99_modFacture_Myworkflow.class.php
By creating such a file with a name like the example, your new trigger file will be executed each time a Dolibarr business event occurs but only if the module Facture is enabled.
Note: If you develop a full module, you can also place the trigger file in your own module's subdirectly. Eg: if your module resides in htdocs/mymodule/, then you can place your triggers inside htdocs/mymodule/core/triggers/. But for this, you must declare the trigger into your module descriptor file (eg: /mymodule/core/modules/modMyModule.class.php). For this, add into this file triggers->1 into module_parts array:
// 'login' => 0,
// 'substitutions' => 0,
// 'menus' => 0);
2) Edit the file interface_99_modMyModule_Myworkflow.class.php to rename class InterfaceMyModuleTriggers by InterfaceMyworkflow
3) Return now to edition of file to add your own code inside function run_trigger.
This function is called at each Dolibarr business event. Put your code according to events on which you want to run. Each event is identified by a code (see following chapter to get full list of codes). So you can react or no after an event by doing just a test on variable $action:
- $object is the object on which action is done (see next chapter)
- $user is the object containing all information of Dolibarr user that realizes the business event.
- $langs is the object that contains the user language and translations strings
- $conf is the object that contains all the Dolibarr configuration.
4) Once your trigger file has been developed, last action is to test by using Dolibarr to execute the business event that should trigger your code. Warning, call of function run_trigger is encapsulated into a transaction. If your code return a KO code, the calling function may rollback the transaction (this depends on calling function).
Add log information inside your function run_trigger to know if your code is correctly triggered and runs correctly. For this, you can use the function
List of known triggers actions
| Trigger code ($action) | Type object ($object) |
| USER_CREATE | user.class.php |
| USER_MODIFY | user.class.php |
| USER_DELETE | user.class.php |
| USER_LOGIN | user.class.php |
| USER_LOGIN_FAILED | user.class.php |
| USER_LOGOUT | user.class.php |
| USER_ENABLEDISABLE | user.class.php |
| USER_NEW_PASSWORD | user.class.php |
| USER_SETINGROUP | user.class.php |
| USER_REMOVEFROMGROUP | user.class.php |
| USERGROUP_CREATE (>= 12.0.0) | usergroup.class.php |
| USERGROUP_MODIFY(>= 12.0.0) | usergroup.class.php |
| USERGROUP_DELETE(>= 12.0.0) | usergroup.class.php |
| GROUP_CREATE | usergroup.class.php |
| GROUP_MODIFY | usergroup.class.php |
| GROUP_DELETE (>= 3.3.0) | usergroup.class.php |
| COMPANY_CREATE | societe.class.php |
| COMPANY_MODIFY | societe.class.php |
| COMPANY_DELETE | societe.class.php |
| COMPANY_SENTBYMAIL (>= 3.5.0) | societe.class.php |
| CONTACT_CREATE | contact.class.php |
| CONTACT_MODIFY | contact.class.php |
| CONTACT_DELETE | contact.class.php |
| CONTACT_ENABLEDISABLE (>= 3.5.0) | contact.class.php |
| PRODUCT_CREATE | product.class.php |
| PRODUCT_MODIFY | product.class.php |
| PRODUCT_PRICE_MODIFY | product.class.php |
| PRODUCT_DELETE | product.class.php |
| SUPPLIER_PRODUCT_BUYPRICE_MODIFY | fournisseur.product.class.php |
| SUPPLIER_PRODUCT_BUYPRICE_CREATE | fournisseur.product.class.php |
| ORDER_CREATE | commande.class.php |
| ORDER_VALIDATE | commande.class.php |
| ORDER_SENTBYMAIL | commande.class.php |
| ORDER_DELETE | commande.class.php |
| ORDER_MODIFY | commande.class.php |
| ORDER_CLASSIFY_BILLED | commande.class.php |
| ORDER_CLONE | commande.class.php |
| ORDER_CLOSE | commande.class.php |
| ORDER_CANCEL | commande.class.php |
| ORDER_REOPEN (>= 3.3.0) | commande.class.php |
| ORDER_UNVALIDATE | commande.class.php |
| COMMANDE_ADD_CONTACT | commande.class.php |
| COMMANDE_DELETE_CONTACT | commande.class.php |
| COMMANDE_DELETE_RESOURCE (>= 3.6.0) | commande.class.php |
| LINEORDER_INSERT | commande.class.php |
| LINEORDER_UPDATE | commande.class.php |
| LINEORDER_DELETE | commande.class.php |
| LINEORDER_DISPATCH (>= 3.4.0) | commande.class.php |
| ORDER_SUPPLIER_CREATE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_CLONE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_VALIDATE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_SENTBYMAIL | fournisseur.commande.class.php |
| ORDER_SUPPLIER_APPROVE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_REFUSE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_CANCEL | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DISPATCH (>= 3.4.0) | fournisseur.commande.class.php |
| ORDER_SUPPLIER_ADD_CONTACT | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE_CONTACT | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE_RESOURCE (>= 3.6.0) | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_CREATE | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_UPDATE | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_DELETE (>= 3.6.0) | fournisseur.commande.class.php |
| PROPAL_CREATE | propal.class.php |
| PROPAL_DELETE | propal.class.php |
| PROPAL_CLONE | propal.class.php |
| PROPAL_REOPEN (>= 3.5.0) | propal.class.php |
| PROPAL_VALIDATE | propal.class.php |
| PROPAL_CLOSE_SIGNED | propal.class.php |
| PROPAL_CLOSE_REFUSED | propal.class.php |
| PROPAL_SENTBYMAIL | propal.class.php |
| PROPAL_MODIFY | propal.class.php |
| PROPAL_ADD_CONTACT | propal.class.php |
| PROPAL_DELETE_CONTACT | propal.class.php |
| PROPAL_DELETE_RESOURCE (>= 3.6.0) | propal.class.php |
| LINEPROPAL_INSERT | propal.class.php |
| LINEPROPAL_UPDATE | propal.class.php |
| LINEPROPAL_DELETE | propal.class.php |
| CONTRACT_CREATE | contrat.class.php |
| CONTRACT_VALIDATE | contrat.class.php |
| CONTRACT_SERVICE_ACTIVATE | contrat.class.php |
| CONTRACT_SERVICE_CLOSE | contrat.class.php |
| CONTRACT_DELETE | contrat.class.php |
| CONTRAT_ADD_CONTACT | contrat.class.php |
| CONTRAT_DELETE_CONTACT | contrat.class.php |
| CONTRAT_DELETE_RESOURCE (>= 3.6.0) | contrat.class.php |
| LINECONTRACT_INSERT | contrat.class.php |
| LINECONTRACT_MODIFY | contrat.class.php |
| LINECONTRACT_DELETE | contrat.class.php |
| BILL_CREATE | facture.class.php |
| BILL_MODIFY | facture.class.php |
| BILL_CLONE | facture.class.php |
| BILL_VALIDATE | facture.class.php |
| BILL_UNVALIDATE (>= 3.4.0) | facture.class.php |
| BILL_PAYED | facture.class.php |
| BILL_UNPAYED | facture.class.php |
| BILL_CANCEL | facture.class.php |
| BILL_DELETE | facture.class.php |
| BILL_SENTBYMAIL | facture.class.php |
| FACTURE_ADD_CONTACT | facture.class.php |
| FACTURE_DELETE_CONTACT | facture.class.php |
| FACTURE_DELETE_RESOURCE (>= 3.6.0) | facture.class.php |
| LINEBILL_INSERT | facture.class.php |
| LINEBILL_UPDATE | facture.class.php |
| LINEBILL_DELETE | facture.class.php |
| BILL_SUPPLIER_CREATE | fournisseur.facture.class.php |
| BILL_SUPPLIER_MODIFY | fournisseur.facture.class.php |
| BILL_SUPPLIER_DELETE | fournisseur.facture.class.php |
| BILL_SUPPLIER_VALIDATE | fournisseur.facture.class.php |
| BILL_SUPPLIER_PAYED | fournisseur.facture.class.php |
| BILL_SUPPLIER_UNPAYED | fournisseur.facture.class.php |
| BILL_SUPPLIER_SENTBYMAIL | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_ADD_CONTACT | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_DELETE_CONTACT | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_DELETE_RESOURCE (>= 3.6.0) | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_CREATE | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_UPDATE | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_DELETE (>= 3.4.0) | fournisseur.facture.class.php |
| PAYMENT_CUSTOMER_CREATE | paiement.class.php |
| PAYMENT_DELETE (<= 3.8) | paiement.class.php |
| PAYMENT_CUSTOMER_DELETE (>= 3.9) | paiement.class.php |
| PAYMENT_ADD_TO_BANK | paiement.class.php |
| PAYMENT_SUPPLIER_CREATE | paiementfourn.class.php |
| PAYMENT_SUPPLIER_DELETE (>= 3.9) | paiement.class.php |
| PAYMENT_SALARY_CREATE (>= 3.6.0) | paymentsalary.class.php |
| PAYMENT_SALARY_MODIFY (>= 3.6.0) | paymentsalary.class.php |
| PAYMENT_SALARY_DELETE (>= 3.6.0) | paymentsalary.class.php |
| FICHINTER_CREATE | fichinter.class.php |
| FICHINTER_MODIFY | fichinter.class.php |
| FICHINTER_DELETE | fichinter.class.php |
| FICHINTER_VALIDATE | fichinter.class.php |
| FICHINTER_SENTBYMAIL | fichinter.class.php |
| FICHINTER_ADD_CONTACT | fichinter.class.php |
| FICHINTER_DELETE_CONTACT | fichinter.class.php |
| FICHINTER_DELETE_RESOURCE (>= 3.6.0) | fichinter.class.php |
| LINEFICHINTER_CREATE (>= 3.5.0) | fichinter.class.php |
| LINEFICHINTER_UPDATE (>= 3.5.0) | fichinter.class.php |
| LINEFICHINTER_DELETE (>= 3.5.0) | fichinter.class.php |
| MEMBER_CREATE | adherent.class.php |
| MEMBER_VALIDATE | adherent.class.php |
| MEMBER_SUBSCRIPTION | adherent.class.php |
| MEMBER_MODIFY | adherent.class.php |
| MEMBER_RESILIATE | adherent.class.php |
| MEMBER_NEW_PASSWORD | adherent.class.php |
| MEMBER_DELETE | adherent.class.php |
| CATEGORY_CREATE | category.class.php |
| CATEGORY_MODIFY | category.class.php |
| CATEGORY_DELETE | category.class.php |
| CATEGORY_LINK (>= 3.5.0) | category.class.php |
| CATEGORY_UNLINK (>= 3.5.0) | category.class.php |
| SHIPPING_CREATE | expedition.class.php |
| SHIPPING_VALIDATE | expedition.class.php |
| SHIPPING_MODIFY | expedition.class.php |
| SHIPPING_DELETE | expedition.class.php |
| SHIPPING_SENTBYMAIL | expedition.class.php |
| DELIVERY_VALIDATE | livraison.class.php |
| DELIVERY_DELETE | livraison.class.php |
| ACTION_CREATE | actioncomm.class.php |
| ACTION_MODIFY | actioncomm.class.php |
| ACTION_DELETE | actioncomm.class.php |
| ACTION_ADD_CONTACT | actioncomm.class.php |
| ACTION_DELETE_CONTACT | actioncomm.class.php |
| ACTION_DELETE_RESOURCE (>= 3.6.0) | actioncomm.class.php |
| DEPLACEMENT_CREATE | deplacement.class.php |
| DON_CREATE | don.class.php |
| DON_MODIFY (>= 3.7.0) | don.class.php |
| DON_DELETE (>= 3.7.0) | don.class.php |
| LOCALTAX_CREATE | localtax.class.php |
| LOCALTAX_MODIFY | localtax.class.php |
| LOCALTAX_DELETE | localtax.class.php |
| TVA_CREATE | tva.class.php |
| TVA_MODIFY | tva.class.php |
| TVA_DELETE | tva.class.php |
| TVA_ADDPAYMENT | tva.class.php |
| PROJECT_CREATE | project.class.php |
| PROJECT_MODIFY | project.class.php |
| PROJECT_DELETE | project.class.php |
| PROJECT_VALIDATE | project.class.php |
| PROJECT_CLOSE | project.class.php |
| PROJECT_ADD_CONTACT | project.class.php |
| PROJECT_DELETE_CONTACT | project.class.php |
| PROJECT_DELETE_RESOURCE (>= 3.6.0) | project.class.php |
| TASK_CREATE | task.class.php |
| TASK_MODIFY | task.class.php |
| TASK_DELETE | task.class.php |
| TASK_TIMESPENT_CREATE | task.class.php |
| TASK_TIMESPENT_MODIFY | task.class.php |
| TASK_TIMESPENT_DELETE | task.class.php |
| PROJECT_TASK_ADD_CONTACT | task.class.php |
| PROJECT_TASK_DELETE_CONTACT | task.class.php |
| PROJECT_TASK_DELETE_RESOURCE (>= 3.6.0) | task.class.php |
| MYECMDIR_CREATE | ecmdirectory.class.php |
| MYECMDIR_MODIFY | ecmdirectory.class.php |
| MYECMDIR_DELETE | ecmdirectory.class.php |
| STOCK_MOVEMENT | mouvementstock.class.php |
| PAYBOX_PAYMENT_OK | |
| PAYPAL_PAYMENT_OK | |
| LINK_CREATE (>= 3.5.0) | link.class.php |
| LINK_MODIFY (>= 3.5.0) | link.class.php |
| LINK_DELETE (>= 3.5.0) | link.class.php |
| OPENSURVEY_CREATE (>= 3.6.0) | opensurveysondage.class.php |
| OPENSURVEY_DELETE (>= 3.6.0) | opensurveysondage.class.php |
| TICKET_CREATE | ticket.class.php |
| TICKET_MODIFY | ticket.class.php |
| TICKET_DELETE | ticket.class.php |
| TICKET_ASSIGNED | ticket.class.php |
| TICKET_CLOSE | ticket.class.php |
Manage and create a new trigger's action
To manage events other than those above, you must modify the Dolibarr code to add the following sequence in the business methods of the classes of the objects handled:
// Call trigger
$result = $this->call_trigger('CODE_TRIGGER', $user);
if ($result <0) $error++;
// End call triggers
To add context information (for example to dissociate 2 different cases called with the same Trigger code), it is possible to place this information in the properties ->context of the object on which the trigger is called. Example:
// Call trigger
$this->context = array('paramX'=>$valueX, 'anyparamofyourchoice'=>$anyvalue);
$result = $this->call_trigger('CODE_TRIGGER',$user);
if ($result < 0) $error++;
It will then be possible to add in the run_trigger method of any trigger file, an if which allows you to manage this code. The run_trigger method would then be of the form:
if ($action == 'XXXXX_YYYYY')
Please note the following before adding additional calls to triggers:
The rule is to have only 1 trigger call per business CRUD event, even when several actions are done in the same transaction. As an example: When a new ticket is created with an already assigned user, only the TICKET_CREATE trigger is called, not additionally the TICKET_ASSIGNED trigger. It is the job of the trigger to intercept also this case to scan if an assignment is done directly during creation and to execute its custom code.
Conclusion
