Triggers system
Execute your own code on a Dolibarr business event
To execute personalized code after a Dolibarr event (create/modify/remove a third party/invoice/product or other), Dolibarr offers a mechanism of business triggers. This mechanism allows you to personalize a work-flow to have Dolibarr business events being synchronized into another application for example. You can also use triggers to modify the behavior of Dolibarr itself: for example, to create automatically a contract when an invoice is validated.
Note that triggers is a feature for developers that is limited to business CRUD events (Create | Read | Update | Delete). There is another features for developers to inject custom code in application called the Hooks system.
1) Copy the trigger file htdocs/core/triggers/interface_90_all_Demo.class.php-NORUN under the new name:
- interface_99_all_Xxx.class.php
or
- interface_99_modMyModule_Xxx.class.php
Note: Value you can use for mod MyModule are values found in directory htdocs/includes/modules.
For example, you can name your new trigger file: htdocs/includes/triggers/interface_99_modFacture_Myworkflow.class.php
Note: With Dolibarr 3.2+, you can also place the triggers in your own module's subdirectly. Eg: if your module resides in htdocs/mymodule/, then you can place your triggers inside htdocs/mymodule/core/triggers/. But for this, you must declare the trigger into your module descriptor file (eg: /mymodule/core/modules/modMyModule.class.php). For this, add into this file triggers->1 into module_parts array:
// 'login' => 0,
// 'substitutions' => 0,
// 'menus' => 0);
2) Edit the file interface_99_modMyModule_Myworkflow.class.php to rename class InterfaceDemo by InterfaceMyworkflow
3) Return now to edition of file to add your own code inside function run_trigger.
This function is called at each Dolibarr business event. Put your code according to events on which you want to run. Each event is identified by a code (see following chapter to get full list of codes). So you can react or no after an event by doing just a test on variable $action:
- $object is the object on which action is done (see next chapter)
- $user is the object containing all information of Dolibarr user that realizes the business event.
- $langs is the object that contains the user language and translations strings
- $conf is the object that contains all the Dolibarr configuration.
4) Once your trigger file has been developed, last action is to test by using Dolibarr to execute the business event that should trigger your code. Warning, call of function run_trigger is encapsulated into a transaction. If your code return a KO code, the calling function may rollback the transaction (this depends on calling function).
Add log information inside your function run_trigger to know if your code is correctly triggered and runs correctly. For this, you can use the function
List of known triggers actions
| Trigger code ($action) | Type object ($object) |
| USER_CREATE | user.class.php |
| USER_MODIFY | user.class.php |
| USER_DELETE | user.class.php |
| USER_LOGIN | user.class.php |
| USER_LOGIN_FAILED | user.class.php |
| USER_LOGOUT | user.class.php |
| USER_ENABLEDISABLE | user.class.php |
| USER_NEW_PASSWORD | user.class.php |
| USER_SETINGROUP | user.class.php |
| USER_REMOVEFROMGROUP | user.class.php |
| USERGROUP_CREATE (>= 12.0.0) | usergroup.class.php |
| USERGROUP_MODIFY(>= 12.0.0) | usergroup.class.php |
| USERGROUP_DELETE(>= 12.0.0) | usergroup.class.php |
| GROUP_CREATE | usergroup.class.php |
| GROUP_MODIFY | usergroup.class.php |
| GROUP_DELETE (>= 3.3.0) | usergroup.class.php |
| COMPANY_CREATE | societe.class.php |
| COMPANY_MODIFY | societe.class.php |
| COMPANY_DELETE | societe.class.php |
| COMPANY_SENTBYMAIL (>= 3.5.0) | societe.class.php |
| CONTACT_CREATE | contact.class.php |
| CONTACT_MODIFY | contact.class.php |
| CONTACT_DELETE | contact.class.php |
| CONTACT_ENABLEDISABLE (>= 3.5.0) | contact.class.php |
| PRODUCT_CREATE | product.class.php |
| PRODUCT_MODIFY | product.class.php |
| PRODUCT_PRICE_MODIFY | product.class.php |
| PRODUCT_DELETE | product.class.php |
| SUPPLIER_PRODUCT_BUYPRICE_MODIFY | fournisseur.product.class.php |
| SUPPLIER_PRODUCT_BUYPRICE_CREATE | fournisseur.product.class.php |
| ORDER_CREATE | commande.class.php |
| ORDER_VALIDATE | commande.class.php |
| ORDER_SENTBYMAIL | commande.class.php |
| ORDER_DELETE | commande.class.php |
| ORDER_MODIFY | commande.class.php |
| ORDER_CLASSIFY_BILLED | commande.class.php |
| ORDER_CLONE | commande.class.php |
| ORDER_CLOSE | commande.class.php |
| ORDER_CANCEL | commande.class.php |
| ORDER_REOPEN (>= 3.3.0) | commande.class.php |
| ORDER_UNVALIDATE | commande.class.php |
| COMMANDE_ADD_CONTACT | commande.class.php |
| COMMANDE_DELETE_CONTACT | commande.class.php |
| COMMANDE_DELETE_RESOURCE (>= 3.6.0) | commande.class.php |
| LINEORDER_INSERT | commande.class.php |
| LINEORDER_UPDATE | commande.class.php |
| LINEORDER_DELETE | commande.class.php |
| LINEORDER_DISPATCH (>= 3.4.0) | commande.class.php |
| ORDER_SUPPLIER_CREATE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_CLONE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_VALIDATE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_SENTBYMAIL | fournisseur.commande.class.php |
| ORDER_SUPPLIER_APPROVE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_REFUSE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_CANCEL | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DISPATCH (>= 3.4.0) | fournisseur.commande.class.php |
| ORDER_SUPPLIER_ADD_CONTACT | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE_CONTACT | fournisseur.commande.class.php |
| ORDER_SUPPLIER_DELETE_RESOURCE (>= 3.6.0) | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_CREATE | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_UPDATE | fournisseur.commande.class.php |
| LINEORDER_SUPPLIER_DELETE (>= 3.6.0) | fournisseur.commande.class.php |
| PROPAL_CREATE | propal.class.php |
| PROPAL_DELETE | propal.class.php |
| PROPAL_CLONE | propal.class.php |
| PROPAL_REOPEN (>= 3.5.0) | propal.class.php |
| PROPAL_VALIDATE | propal.class.php |
| PROPAL_CLOSE_SIGNED | propal.class.php |
| PROPAL_CLOSE_REFUSED | propal.class.php |
| PROPAL_SENTBYMAIL | propal.class.php |
| PROPAL_MODIFY | propal.class.php |
| PROPAL_ADD_CONTACT | propal.class.php |
| PROPAL_DELETE_CONTACT | propal.class.php |
| PROPAL_DELETE_RESOURCE (>= 3.6.0) | propal.class.php |
| LINEPROPAL_INSERT | propal.class.php |
| LINEPROPAL_UPDATE | propal.class.php |
| LINEPROPAL_DELETE | propal.class.php |
| CONTRACT_CREATE | contrat.class.php |
| CONTRACT_VALIDATE | contrat.class.php |
| CONTRACT_SERVICE_ACTIVATE | contrat.class.php |
| CONTRACT_SERVICE_CLOSE | contrat.class.php |
| CONTRACT_DELETE | contrat.class.php |
| CONTRAT_ADD_CONTACT | contrat.class.php |
| CONTRAT_DELETE_CONTACT | contrat.class.php |
| CONTRAT_DELETE_RESOURCE (>= 3.6.0) | contrat.class.php |
| LINECONTRACT_INSERT | contrat.class.php |
| LINECONTRACT_MODIFY | contrat.class.php |
| LINECONTRACT_DELETE | contrat.class.php |
| BILL_CREATE | facture.class.php |
| BILL_MODIFY | facture.class.php |
| BILL_CLONE | facture.class.php |
| BILL_VALIDATE | facture.class.php |
| BILL_UNVALIDATE (>= 3.4.0) | facture.class.php |
| BILL_PAYED | facture.class.php |
| BILL_UNPAYED | facture.class.php |
| BILL_CANCEL | facture.class.php |
| BILL_DELETE | facture.class.php |
| BILL_SENTBYMAIL | facture.class.php |
| FACTURE_ADD_CONTACT | facture.class.php |
| FACTURE_DELETE_CONTACT | facture.class.php |
| FACTURE_DELETE_RESOURCE (>= 3.6.0) | facture.class.php |
| LINEBILL_INSERT | facture.class.php |
| LINEBILL_UPDATE | facture.class.php |
| LINEBILL_DELETE | facture.class.php |
| BILL_SUPPLIER_CREATE | fournisseur.facture.class.php |
| BILL_SUPPLIER_MODIFY | fournisseur.facture.class.php |
| BILL_SUPPLIER_DELETE | fournisseur.facture.class.php |
| BILL_SUPPLIER_VALIDATE | fournisseur.facture.class.php |
| BILL_SUPPLIER_PAYED | fournisseur.facture.class.php |
| BILL_SUPPLIER_UNPAYED | fournisseur.facture.class.php |
| BILL_SUPPLIER_SENTBYMAIL | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_ADD_CONTACT | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_DELETE_CONTACT | fournisseur.facture.class.php |
| INVOICE_SUPPLIER_DELETE_RESOURCE (>= 3.6.0) | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_CREATE | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_UPDATE | fournisseur.facture.class.php |
| LINEBILL_SUPPLIER_DELETE (>= 3.4.0) | fournisseur.facture.class.php |
| PAYMENT_CUSTOMER_CREATE | paiement.class.php |
| PAYMENT_DELETE (<= 3.8) | paiement.class.php |
| PAYMENT_CUSTOMER_DELETE (>= 3.9) | paiement.class.php |
| PAYMENT_ADD_TO_BANK | paiement.class.php |
| PAYMENT_SUPPLIER_CREATE | paiementfourn.class.php |
| PAYMENT_SUPPLIER_DELETE (>= 3.9) | paiement.class.php |
| PAYMENT_SALARY_CREATE (>= 3.6.0) | paymentsalary.class.php |
| PAYMENT_SALARY_MODIFY (>= 3.6.0) | paymentsalary.class.php |
| PAYMENT_SALARY_DELETE (>= 3.6.0) | paymentsalary.class.php |
| FICHINTER_CREATE | fichinter.class.php |
| FICHINTER_MODIFY | fichinter.class.php |
| FICHINTER_DELETE | fichinter.class.php |
| FICHINTER_VALIDATE | fichinter.class.php |
| FICHINTER_SENTBYMAIL | fichinter.class.php |
| FICHINTER_ADD_CONTACT | fichinter.class.php |
| FICHINTER_DELETE_CONTACT | fichinter.class.php |
| FICHINTER_DELETE_RESOURCE (>= 3.6.0) | fichinter.class.php |
| LINEFICHINTER_CREATE (>= 3.5.0) | fichinter.class.php |
| LINEFICHINTER_UPDATE (>= 3.5.0) | fichinter.class.php |
| LINEFICHINTER_DELETE (>= 3.5.0) | fichinter.class.php |
| MEMBER_CREATE | adherent.class.php |
| MEMBER_VALIDATE | adherent.class.php |
| MEMBER_SUBSCRIPTION | adherent.class.php |
| MEMBER_MODIFY | adherent.class.php |
| MEMBER_RESILIATE | adherent.class.php |
| MEMBER_NEW_PASSWORD | adherent.class.php |
| MEMBER_DELETE | adherent.class.php |
| CATEGORY_CREATE | category.class.php |
| CATEGORY_MODIFY | category.class.php |
| CATEGORY_DELETE | category.class.php |
| CATEGORY_LINK (>= 3.5.0) | category.class.php |
| CATEGORY_UNLINK (>= 3.5.0) | category.class.php |
| SHIPPING_CREATE | expedition.class.php |
| SHIPPING_VALIDATE | expedition.class.php |
| SHIPPING_MODIFY | expedition.class.php |
| SHIPPING_DELETE | expedition.class.php |
| SHIPPING_SENTBYMAIL | expedition.class.php |
| DELIVERY_VALIDATE | livraison.class.php |
| DELIVERY_DELETE | livraison.class.php |
| ACTION_CREATE | actioncomm.class.php |
| ACTION_MODIFY | actioncomm.class.php |
| ACTION_DELETE | actioncomm.class.php |
| ACTION_ADD_CONTACT | actioncomm.class.php |
| ACTION_DELETE_CONTACT | actioncomm.class.php |
| ACTION_DELETE_RESOURCE (>= 3.6.0) | actioncomm.class.php |
| DEPLACEMENT_CREATE | deplacement.class.php |
| DON_CREATE | don.class.php |
| DON_MODIFY (>= 3.7.0) | don.class.php |
| DON_DELETE (>= 3.7.0) | don.class.php |
| LOCALTAX_CREATE | localtax.class.php |
| LOCALTAX_MODIFY | localtax.class.php |
| LOCALTAX_DELETE | localtax.class.php |
| TVA_CREATE | tva.class.php |
| TVA_MODIFY | tva.class.php |
| TVA_DELETE | tva.class.php |
| TVA_ADDPAYMENT | tva.class.php |
| PROJECT_CREATE | project.class.php |
| PROJECT_MODIFY | project.class.php |
| PROJECT_DELETE | project.class.php |
| PROJECT_VALIDATE | project.class.php |
| PROJECT_CLOSE | project.class.php |
| PROJECT_ADD_CONTACT | project.class.php |
| PROJECT_DELETE_CONTACT | project.class.php |
| PROJECT_DELETE_RESOURCE (>= 3.6.0) | project.class.php |
| TASK_CREATE | task.class.php |
| TASK_MODIFY | task.class.php |
| TASK_DELETE | task.class.php |
| TASK_TIMESPENT_CREATE | task.class.php |
| TASK_TIMESPENT_MODIFY | task.class.php |
| TASK_TIMESPENT_DELETE | task.class.php |
| PROJECT_TASK_ADD_CONTACT | task.class.php |
| PROJECT_TASK_DELETE_CONTACT | task.class.php |
| PROJECT_TASK_DELETE_RESOURCE (>= 3.6.0) | task.class.php |
| MYECMDIR_CREATE | ecmdirectory.class.php |
| MYECMDIR_MODIFY | ecmdirectory.class.php |
| MYECMDIR_DELETE | ecmdirectory.class.php |
| STOCK_MOVEMENT | mouvementstock.class.php |
| PAYBOX_PAYMENT_OK | |
| PAYPAL_PAYMENT_OK | |
| LINK_CREATE (>= 3.5.0) | link.class.php |
| LINK_MODIFY (>= 3.5.0) | link.class.php |
| LINK_DELETE (>= 3.5.0) | link.class.php |
| OPENSURVEY_CREATE (>= 3.6.0) | opensurveysondage.class.php |
| OPENSURVEY_DELETE (>= 3.6.0) | opensurveysondage.class.php |
| TICKET_CREATE | ticket.class.php |
| TICKET_MODIFY | ticket.class.php |
| TICKET_DELETE | ticket.class.php |
| TICKET_ASSIGNED | ticket.class.php |
| TICKET_CLOSE | ticket.class.php |
Manage and create a new trigger's action
To manage events other than those above, you must modify the Dolibarr code to add the following sequence in the business methods of the classes of the objects handled:
// Call trigger
//$this->context = array('paramX'=>$valueX);
$result = $this->call_trigger('XXXXX_YYYYY', $user);
if ($result <0) $error++;
// End call triggers
It will then be possible to add in the run_trigger method of any trigger file, an if which allows you to manage this code. The run_trigger method would then be of the form:
if ($action == 'XXXXX_YYYYY')
Conclusion
