Module Place
Revision as of 13:21, 23 July 2019 by PolyglotBot (talk | contribs) (Import interlang links (links to translated versions of this page in other languages) from Multi Language Manager table.)
Place
Numéro/ID du module 110110
Doc développeur du module Module Place (developer)
Module name Place
Editor / Editeur Librethic (librethic.io) - Project page on Librethic forge
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/fr/modules/1033-Module-Place.html
Add locations, buildings, floors and rooms within Dolibarr ERP/CRM. Can add locations and rooms as a resource to an action from agenda.
