Prerequisites
Revision as of 14:32, 12 March 2009 by Eldy (talk | contribs)
Dolibarr was build to work on following components :
OS
  • Every OS are supported.
For example: Linux, BSD, Windows, MacOS, Aix, ...
Database
  • Mysql 3.1 or + (4.1 or more is recommanded)
If using option mode=STRICT returns some warnings or error, please report them to us.
  • PostgresSql (experimental support not working yet)
  • MSSql (experimental support not working yet)
PHP
  • Version 4.3.10 or more (need support of the "%0.2F" of the sprintf PHP function to make PDF generation working)
  • Support of user sessions must be enabled (it is the cas by default in PHP)
  • Works whatever is the parameter register_globals
  • Works whatever is the parameter magick_quotes
  • Works whatever is the parameter safe_mode
  • PHP configuration must allow use of a max of 16Mb of memory (24Mb required if using Windows).
