Table llx commande fournisseur
Revision as of 11:51, 12 March 2009 by Simnandez (talk | contribs)
Contenu
La table llx_commande_fournisseur contient les commandes fournisseurs (les commandes effectuées auprès des fournisseurs). Ces commandes peuvent plus tard être étendues sous forme de factures fournisseurs, auquel cas c'est la table llx_facture_fourn qui est utilisée, en combinaison (s'il y a un lien entre commande et facture) avec la table llx_comfourn_facfourn.
Contains the provider orders (orders made to the providers). These orders may be later extended as (provider-) invoices, in which case Table llx_facture_fourn is used, in combination (if there is a link between order and invoice) with Table llx_comfourn_facfourn.
Structure
| Field               | Type        | Null | Key | Default           | Extra          |
| rowid               | int(11)     | NO   | PRI | NULL              | auto_increment |
| tms                 | timestamp   | NO   |     | CURRENT_TIMESTAMP |                |
| fk_soc              | int(11)     | NO   | MUL |                   |                |
| fk_projet           | int(11)     | YES  |     | 0                 |                |
| ref                 | varchar(30) | NO   | UNI |                   |                |
| date_creation       | datetime    | YES  |     | NULL              |                |
| date_valid          | datetime    | YES  |     | NULL              |                |
| date_cloture        | datetime    | YES  |     | NULL              |                |
| date_commande       | date        | YES  |     | NULL              |                |
| fk_user_author      | int(11)     | YES  |     | NULL              |                |
| fk_user_valid       | int(11)     | YES  |     | NULL              |                |
| fk_user_cloture     | int(11)     | YES  |     | NULL              |                |
| source              | smallint(6) | NO   |     |                   |                |
| fk_statut           | smallint(6) | YES  |     | 0                 |                | 0 pour brouillon, 1 pour validée, 2 pour "approuvée", 5 pour "reçu complètement"
| amount_ht           | double      | YES  |     | 0                 |                |
| remise_percent      | double      | YES  |     | 0                 |                |
| remise              | double      | YES  |     | 0                 |                |
| tva                 | double      | YES  |     | 0                 |                |
| total_ht            | double      | YES  |     | 0                 |                |
| total_ttc           | double      | YES  |     | 0                 |                |
| note                | text        | YES  |     | NULL              |                |
| note_public         | text        | YES  |     | NULL              |                |
| model_pdf           | varchar(50) | YES  |     | NULL              |                |
| fk_methode_commande | int(11)     | YES  |     | 0                 |                |
