Table llx commande
The documentation related to other tables is available on the page: Table SQL
La documentation relative aux autres tables est disponible sur la page: Table SQL
La documentación relativa a otras tablas se encuentra disponible en la página: Table SQL
Eine Dokumentation zu weiteren Tabellen ist auf dieser Seite verfügbar: Table SQL
与其他表相关的文档请参阅:Table SQL
Contenu
Table principales des commandes clients, les détails de la commande sont dans la Table llx_commandedet
Contains customer orders. The order details are in Table llx_commandedet
Structure
-- =================================================================== -- Copyright (C) 2003 Rodolphe Quiedeville <rodolphe@quiedeville.org> -- -- This program is free software; you can redistribute it and/or modify -- it under the terms of the GNU General Public License as published by -- the Free Software Foundation; either version 2 of the License, or -- (at your option) any later version. -- -- This program is distributed in the hope that it will be useful, -- but WITHOUT ANY WARRANTY; without even the implied warranty of -- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the -- GNU General Public License for more details. -- -- You should have received a copy of the GNU General Public License -- along with this program; if not, write to the Free Software -- Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA. -- -- $Id: llx_commande.sql,v 1.4 2004/10/09 10:47:16 opensides Exp $ -- $Source: /cvsroot/dolibarr/dolibarr/mysql/tables/llx_commande.sql,v $ -- -- =================================================================== create table llx_commande ( rowid integer AUTO_INCREMENT PRIMARY KEY, tms timestamp, fk_soc integer, fk_soc_contact integer, fk_projet integer DEFAULT 0, -- projet auquel est rattache la commande ref varchar(30) NOT NULL, -- propal number date_creation datetime, -- date de creation date_valid datetime, -- date de validation date_cloture datetime, -- date de cloture date_commande date, -- date de la commande fk_user_author integer, -- createur de la commande fk_user_valid integer, -- valideur de la commande fk_user_cloture integer, -- cloture de la propale signee ou non signee source smallint NOT NULL, fk_statut smallint default 0, amount_ht real default 0, remise_percent real default 0, remise real default 0, tva real default 0, total_ht real default 0, total_ttc real default 0, note text, model_pdf varchar(50), facture tinyint default 0, -- flag indiquant si cette commande a été facturée UNIQUE INDEX (ref) )type=innodb;
