Module ProductRefCol
Revision as of 21:59, 28 November 2026 by Agadir-informatique (talk | contribs) (Page of the module (Agadir Informatique))
Editor Agadir Informatique (agadir-informatique.ma)
Module ID 471524
Version 1.0.0
Dolibarr 16 to 24
Where to get it DoliStore
Support contact@agadir-informatique.ma
Shows the reference of each product in its own Ref. column, on the left of the description, in your PDF invoices, proposals and orders, instead of being stuck to the label.
  • "Ref." column right before the description; free lines stay empty.
  • Reference removed from the description so it is not printed twice (option).
  • Supplier documents: supplier reference or your own reference.
  • Long references wrap inside the column without overlapping the next line.
  • Customizable title ("Ref.", "Item code"…) and width; each document type can be enabled separately.
  • Works with the "Line numbers" module.
  • PDF models sponge, octopus, cyan, eratosthene, cornas, zenith.
No Dolibarr core file is modified, no PDF model is copied. GPL v3 licence.
Languages: French and English.
Home → Setup → Modules → "Deploy/install an external module": upload the zip file, then enable the module and open its setup page (gear icon).
Screenshots
Support
Questions before buying, installation or update issues: write to contact@agadir-informatique.ma. Purchase on the DoliStore.
