Concept3D – 3D plan and quote configurator for Dolibarr
Concept3D
Overview
| Module | Concept3D |
| Version | 1.0.1 |
| Dolibarr | 18 → 24 |
| PHP | 8.1+ |
| Databases | MySQL/MariaDB and PostgreSQL 16 and 18 |
| Licence | GNU GPLv3 |
| Éditeur / Publisher | KSIDol.io |
Concept3D (technical name concept3d) is a visual configurator for Dolibarr. You draw your customer's room to scale, drag in the products of your catalogue, show the project in 3D, then get the quote in one click. Everything that is priced stays a native Dolibarr product or service: no catalogue to re-enter, no double entry. The module is aimed at kitchen designers, interior fitters, sellers of furniture, bathrooms, closets, terraces or swimming pools, and shops laying out their aisles.
A plan drawn to scale
Walls are drawn in metres, on a plain background or on an imported image calibrated with two points. Doors and windows are dropped onto a wall. As soon as the walls close, the module recognises the room and works out its floor area and perimeter. Products dragged from the catalogue are drawn at their real dimensions, read from the product card: rotation, magnet, height from floor, lock, duplication, keyboard shortcuts, finger use on a tablet.
The architect's plan, at its real dimensions
An imported plan (a scan, a screenshot or an export from an architecture software, as JPEG, PNG or WebP) is brought to scale by a seven-step layout assistant: framing and straightening, scale read from the dimension chains written on the plan, per axis and per segment, walls and openings detected on the drawing with their real thicknesses, doors, windows and roller shutters taken from the annotations ("P 83 x 204", "VR … All. …"), named and typed rooms, ceiling height, then a final check. A whole house ends up in 3D at its real dimensions, ready for pricing and, with the companion modules, for the electrical file.
3D to win the customer over
The 3D view is built in real time from the plan. You import the 3D models of your products (GLB, glTF, OBJ, Collada), choose the floor covering and the wall colour, and walk through the room at eye level. View capture, 360° panorama, GLB export, a read-only presentation mode and a kiosk mode for a showroom screen. The display engine is embedded in the module: no outside service is called.
Pricing that builds up as you place
- Quantities derived from the product unit: a worktop sold by the linear metre or a covering sold by the square metre is priced from its placed dimensions.
- Automatic installation rules: labour is added by itself, as a percentage, a flat fee, per metre, per square metre or per hour.
- Discounts per line and overall, with the total readable before and after discount.
- Margin and margin rate shown only to users holding the dedicated permission.
- Finishes through the native Dolibarr product variants, and custom sizes within limits set on the product card.
From the quote to the installation
- Native quote in one click: a draft Dolibarr commercial proposal with every line, discounts and purchase prices, the linked project and the plan PDF attached.
- Sales follow-up: in study, presented, won, lost with its reason; variants of the same project compared.
- Installation file without prices: plan with numbered objects, installation list, elevations wall by wall.
- Purchasing: products grouped by supplier, native supplier order created as a draft.
- Exports: presentation PDF, plan in SVG at 1:50 scale, 3D scene in GLB.
Seven trades preset
Kitchen, bathroom, closet, furniture, terrace, swimming pool, shop: each usage profile sets the default dimensions, the catalogue category, the wall height, the sill, the minimum aisle and the tiling calculator. Room templates, technical zones and plan checks: object outside the frame, overlap, wall crossed, aisle too narrow, forbidden zone. The tiling calculator works out the number of tiles, boards or slabs, joints and waste included.
Optional: the electrical file with SchémaConcept
With two companion modules, Bridge Concept3D / SchémaConcept and SchémaConcept, the plan becomes an electrical file. Room by room, the bridge works out the sockets, lighting, network and alarm points, explaining each one, then sends in one click the diagram, the distribution board and its circuits, the single-line diagram and a layout plan at 1:50 scale. Each device is a Dolibarr product: the bill of materials is priced live, with the total and the margin, and becomes a Dolibarr quote in one click. What you have drawn is never changed. The rules follow a country standards profile: they are proposals to be validated by a qualified professional, not a certificate of compliance. Both modules are installed on top of Concept3D, which works fully without them.
See also: Bridge Concept3D / SchémaConcept · SchémaConcept on KSIDol
What is included
The complete module, its setup (settings, installation rules, usage profiles), the 3D model library and its importer, the PDF documents, five separate permissions and five languages: French, English, German, Spanish, Italian. GPL v3 licence.
What is not included
3D models are not shipped with the module: you import your own or those of free libraries, whose sources and licences are listed on a page of the module. Finishes need the native Product Variants module, purchasing needs the Purchase Orders module. A plan converted into a quote becomes read-only: corrections are then made on the native quote.
Compatibility and requirements
Dolibarr 18 to 24, run-tested on 18.0.6 and on 24 with a suite of more than 580 automated checks, none failing. PHP 8.1 or later. Third parties, Products and Proposals modules enabled.
Requirements
- Dolibarr 18 → 24
- PHP 8.1+
- Databases: MySQL/MariaDB and PostgreSQL 16 and 18
- A Dolibarr administrator account for activation and setup
- Extract the module archive.
- Copy the module folder into
htdocs/custom/. - In Dolibarr, open Home → Setup → Modules/Applications and enable the module.
- Grant the required permissions to the relevant users or groups.
- Open the module setup page and review its settings before going live.
Update
Before updating, back up the Dolibarr database and documents. Replace the module folder with the new version, then open its setup page to apply any migrations.
Rights and permissions
Access is controlled through Dolibarr permissions. Grant each business role only the rights it needs.
Support and purchase
Pre-sales questions and support: https://www.ksidol.io/contact — purchase from the KSIDol.io shop: https://www.ksidol.io
Official links
- Demo video : Concept3D — demo (YouTube)
- Module page : Concept3D on KSIDol
- Online demo : Concept3D — open the demo
- Module user guide : Concept3D — read the guide
