Module Modern Template EN
Revision as of 19:42, 21 November 2026 by KSI (talk | contribs) (Compatibilité : version 24.0.5, Dolibarr 22 à 24, bases de données)
Information
Module name Modern Template
Editor / Editeur KSIDol - https://www.ksidol.io
Download or buy page / Page achat ou téléchargement External module - https://www.dolistore.com/index.php?controller=search&orderby=position&orderway=desc&website=marketplace&search_query=k.s.i&submit_search=
Status / Statut / Estado
Last update date / Date mise à jour fiche / Fecha última actualización 2026-11-21
Note / Nota Modern interface for Dolibarr with navigation portal, tiles, submenus, quick search, personalization and integrated administration.
     Dolibarr module
     User interface
     Modern navigation
     EN documentation
Modern Template
Modern interface, user portal and fast navigation for Dolibarr
Modern Template improves the daily Dolibarr experience by providing a centralized workspace with tiles, submenus, quick search, full-screen display, action shortcuts and integrated administration tools.
General overview
The module turns access to Dolibarr into a clear and modern portal. Users find their main business entries as tiles and can work in Dolibarr screens while keeping smoother navigation.
  • Quick access to business modules through configurable tiles.
  • Display of contextual submenus linked to the active tile.
  • Quick search across Dolibarr objects available to the user.
  • Full-screen mode, back, home, print, help, support and logout actions.
  • Administrator settings from a dedicated interface.
  • Integration without modifying the Dolibarr core.
Publisher & support
PublisherKSIDol
SpecialtyDolibarr integrator
ServicesCustom development
HostingSaaS hosting
Websiteksidol.io
Supportsupport@ksidol.io
KSIDol modules on Dolistore: My modules on Dolistore — K.S.I
0
Dolibarr core modification
5
commercial languages presented
1
central user portal
Main features
Navigation portal
Modern Template displays a workspace focused on actual use: business tiles, quick access links, submenus, navigation actions and an integrated display area.
Customizable tiles
Main entries can be adapted, reordered and enriched to provide a portal aligned with the company organization.
Contextual submenus
Each tile can display its secondary links: lists, creation pages, statistics, consultation pages or business actions.
Quick search
The search queries the main Dolibarr objects accessible to the connected user and redirects to the relevant card or list.
Visual personalization
The administrator can adapt colors and selected visual elements to bring the interface closer to the company brand identity.
Integrated administration
Settings are available from a tabbed configuration page, with repair, backup, restore and uninstall tools.
User workflow
  1. The user logs in to Dolibarr with the usual credentials.
  2. If the option is enabled for the profile, Modern Template automatically opens the portal after login.
  3. The user selects a business tile to open the corresponding main page.
  4. Associated submenus can be displayed to access secondary actions.
  5. Quick search can be used to find a card or list without browsing through menus.
  6. The user can temporarily switch back to the classic Dolibarr display when required.
Quick search
The internal search respects the permissions of the connected user. It can route the user to the main objects used daily in Dolibarr.
 Third parties
 Contacts
 Customer invoices
 Supplier invoices
 Proposals
 Customer orders
 Supplier orders
 Products / services
 Projects
 Tickets
 Agenda
Available languages
Flag Language Code Availability
???????? French FR Yes
???????? English EN Yes
???????? Italian IT Yes
???????? German DE Yes
???????? Spanish ES Yes
Compatibility
Item Value
Documented version 24.0.5
Dolibarr 22 to 24
Databases MySQL/MariaDB and PostgreSQL 16 and 18
  1. Download the module from Dolistore or from the area provided by KSIDol.
  2. Install the module in the Dolibarr additional modules directory.
  3. Enable the module from the modules/applications configuration menu.
  4. Open the module configuration page.
  5. Use the installation or repair tool if Dolibarr offers it.
  6. Check that the Modern Template menu appears and that the portal opens correctly.
Tip: make a backup before installation or upgrade, especially on a production instance.
Colors tab
Used to adapt the portal appearance: banner, toolbar, main color, accent color, tile background and text. This tab is useful to align the interface with the company visual identity.
Tiles tab
Used to organize the main portal entries. Administrators can add, edit, move or remove tiles and associate secondary links with each section. Backup and restore functions are provided to secure changes.
Rights / ACL tab
Used to manage the visibility of tiles and links by user. This feature helps simplify the interface, reduce navigation errors and reserve selected entries for specific profiles.
Languages tab
Used to administer module labels, scan texts to translate and prepare a consistent interface for multilingual users.
Tools tab
Used to adjust the overall portal behavior: home page, redirection after login, full-screen mode, help links, support, diagnosis and repair. Advanced options should be handled by an administrator.
Dolibarr rights tab
Used to check or display the main permission required to use the module. Dolibarr permissions remain the priority for access to business data.
Setup access tab
Used to choose which configuration tabs are visible to administrators and, where required, to selected users. This avoids exposing advanced settings to profiles that do not need them.
Uninstall tab
Used to remove the elements installed by the module. Complete data deletion should be used only when the administrator really wants to erase the module configuration.
Public technical notice
This section describes the functional architecture of the module without displaying internal values, constant names, table names, file paths, endpoints or SQL queries.
Analyzed element Functional role Recommended public wording
Login trigger Prepares portal opening after authentication according to the defined settings. The module can open Modern Template after login while respecting the user context.
Interface integration points Integrates with menu areas and the upper part of Dolibarr. The module uses standard Dolibarr mechanisms to display its portal and hide native menus when needed.
Configuration settings Store global preferences: display, redirection, colors, help, support and portal behavior. Settings are managed from the configuration interface, without direct manipulation of technical values.
Internal SQL storage Stores preferences and tile structure, with installation, repair, backup and restore. The module has dedicated internal storage for its configuration and portal personalization.
Dolibarr links Connects tiles, submenus and search results to accessible business pages. The module relies on standard Dolibarr menus, rights and objects to keep navigation consistent.
Maintenance functions Repair settings, synchronize installation elements and support migrations from older versions. Repair and maintenance tools are available in the module administration area.
Application security Controls rights, protects sensitive actions and cleans navigation targets. The module respects Dolibarr rights and secures configuration actions.
Administration & maintenance
  • Use the module configuration tab for all common changes.
  • Back up the tile configuration before a major reorganization.
  • Test redirections after login with both an administrator account and a standard user account.
  • Check Dolibarr rights if a tile or search result is not displayed.
  • Use repair functions after an update or migration from an older version.
  • Avoid direct database changes unless handled through supervised technical intervention.
Security & rights
  • The module has a dedicated Dolibarr usage permission.
  • Tiles and links can be restricted to selected users.
  • Search results respect read permissions for the relevant Dolibarr modules.
  • Configuration write actions use Dolibarr session protections.
  • Start and configuration URLs are controlled to reduce the risk of incorrect redirection.
  • The module does not require any Dolibarr core modification.
Uninstallation
  1. Disable automatic redirection if it has been used.
  2. Disable the module in Dolibarr configuration.
  3. Use the uninstall tab only if complete deletion of module data is required.
  4. Remove module files after disabling it, following the usual additional-module procedure.
  5. Check that the user returns to the classic Dolibarr home page.
Warning: complete deletion may remove tile personalization and module preferences. Keep a backup if these elements must be reused.
FAQ
After login, the user lands directly on Modern Template. Is this normal?
Yes, if redirection after login is enabled in the module tools. It can be disabled or limited depending on the desired behavior.
I cannot see some tiles or links. Why?
Visibility may depend on Dolibarr rights, tile restrictions, user settings or modules enabled on the instance.
Does the module replace Dolibarr?
No. Modern Template improves navigation and the user experience, but the pages and data remain Dolibarr pages and data.
Can I personalize access by department or by user?
Yes. Administration allows tiles, submenus and restrictions to be adapted in order to create a simpler interface for each profile.
What should I do before an update?
It is recommended to back up the Dolibarr instance and export the tile configuration if significant personalization has been made.
Useful links
